Thread: Air gap to disposal question
    DIY Junior Member alaskapanic's Avatar
    Jul 2011
    Alaska
    Default Air gap to disposal question
    recently got new countertops and had the countertop guys install the new kitchen faucet and air gap. they had to move the disposal to the right side to accommodate
    the depth of the new sink. anyway, first time they ran the 7/8 hose under the drain pipe and back up into the disposal causing the air gap to spit. i had to tell them that there should be no loop and that it should be a downhill slope on the 7/8 hose from air gap to disposal(scary b/c i don't know much about plumbing). so they did it and it stopped the air gap spitting. i've started noticing a little water seeping out from the base of my new delta kitchen faucet and a little seeping out under the soap dispenser. right at the base where they contact the granite. it's a tiny amount but it's driving me crazy trying to figure out where it's coming from. there are no leaks under the sink, but i did notice the 7/8 hose from air gap to disposal is still kinked some. the way the disposal is positioned the hose always seems to kink no matter how much it's been shortened. so my question is two fold: any tricks on getting that 7/8 hose unkinked(when i've already tried shortening it) and secondly could that kinked hose be causing the tiny amount of water to seep around the base of the kitchen faucet and soap dispenser? for what it's worth even though the hose is kinked we don't get the air gap spitting water when we run the dishwasher. so it must be letting enough water drain.
    thanks for the help
    Jul 2011
    Alaska
    forgot to mention the water that mysteriously seeps at the base of the kitchen faucet and soap dispenser doesn't do it continuously. seems to be connected to when we run the dishwasher, but i can't be certain
    IF you cannot tell where the water is coming from, then we obviously can't either. It sounds like they put the air gap on the wrong side of the sink so the drain hose has to make a turn to get into the disposer. Two possibilities. if it is a new disposer, loosen the bolts holding it together and rotate the top to line up with the air gap, or use 3/4" copper elbows to make the turn.
  1. Garbage disposal question
    By SocialD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2013, 03:32 PM
  2. Disposal Question
    By Sun1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2011, 05:32 PM
  3. Disposal Question
    By PartyGator in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2010, 09:07 PM
  4. Garbage Disposal Question
    By Loocie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2009, 06:54 PM
  5. Will disposal fit?
    By SVWillow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2007, 01:45 PM
