Results 1 to 3 of 3
Thread: How to remove Paulus Water Tight Seal
    DIY Junior Member richard cranium's Avatar
    Apr 2013
    Michigan
    Default How to remove Paulus Water Tight Seal
    I have removed the well cap only to find a Paulus Water Tight seal installed.
    Looking for help to remove it, as I can not see into the casing to find out if I have a leak.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Looks like a regular well seal. Just loosen the bolts, DON'T REMOVE THE BOLTS. Then the seal should pull loose. Somtimes spinnning the seal will help break it loose.
    http://www.paulusplastic.com/wellcapsaccessories.htm
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    It looks as though are lugs under the flange that prevent it from seating all the way down on the casing. Take a hooked pry bar and pry on the flange of the seal to break it loose. I like to work the bar from side to side rather than back n forth.
  1. Irrigation Well - Remove Rusted Seal
    By Adam FL in forum Irrigation / Sprinkler Forum
    Last Post: 04-04-2013, 02:07 PM
  2. Automatic Water Shutoff - Tight Spot
    By Fraser Jim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2013, 06:00 AM
  3. Replies: 8
    Last Post: 02-25-2013, 06:01 AM
  4. Remove Well Seal on a Twin Pipe Deep Well
    By scarrie1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-04-2008, 04:25 PM
  5. water pressure regulator and tight spaces
    By aben in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2005, 03:50 AM
