Thread: Electric Hot Water Heater Code
    DIY Junior Member dentamok's Avatar
    Apr 2013
    Oklahoma
    Default Electric Hot Water Heater Code
    I live in Oklahoma,, and I need a new electric water heater as mine is leaking. Do I have to build a stand to raise the water heater off the floor like you do for a gas powered model. It's currently sitting on the concrete in a drain pan. Can I just replace it on the concrete? Thanks for the help!!
    With the changes in federal requirements on gas WH, you often don't need a stand for gas any more. Local codes may differ. New gas WH have a special flammable vaporproof burner now, and the burner itself is higher with the addition of that design, elevating them often isn't an issue. Now, you still wouldn't want to hit it with the car, so elevating it still has advantages.
    The only time an electric heater has to be on a stand is when it is in a garage where cars could impact it. In that case, steel pipe bollards will also protect it.
  1. Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 09:01 AM
  2. Hot water heater and code questions
    By spebby in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2008, 09:03 AM
  3. Electric Water Heater 30 or 40
    By jimqual7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2008, 08:10 AM
  4. CODE for Water Heater
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2007, 11:16 PM
  5. electric water heater
    By A Casey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-31-2006, 08:06 AM
