Results 1 to 6 of 6
Thread: DWV Design
    DIY Junior Member Wilson22's Avatar
    Apr 2013
    BC
    Default DWV Design
    Having glued up the following I'm having serious doubts about my design and thought it best to ask the experts. I'd call a local plumber but sadly my location is sufficiently remote that travel time is a killer. In fact, I'm sufficiently remote that we have no plumbing or building inspection. So the attached is a bathroom backing on to a laundry room. The closet riser is 4, the main outlet 3 and the others are 2.
    Name:  IMG_5552 - Copy.jpg
    I guess my question is: Will this work and can I vent the toilet via the shower vent. If not, what is the simplest remedy? Im not too worried about code but rightly worried about function and longevity. Hidden in the sand is the shower's P-Trap. Any input would be greatly appreciated.
    Wilson
    Since you have used a 2" wye fitting for the shower, that will legally vent the toilet.
    The lav, washer and shower vents can tie together at 42" above the floor and then extend through the roof.
    What you have looks nice.
    Apr 2013
    BC
    Terry,
    You just made my day! Thank you so much!
    We have to assume those are long sweep elbows at the bottom of the sink and laundry risers.
    Nov 2010
    Maine
    Here the laundry and shower can't be on the same 2" lateral
    It looks like his laundry 2" wyes into the 3", same as for the shower.
  1. Is my DWV Design OK ?
    By takelargebites in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2011, 12:39 PM
  2. ADA Design
    By gsensel in forum Toilet Forum discussions
    Last Post: 07-21-2010, 04:39 PM
  3. what do you think about this design?
    By v1rtu0s1ty in forum Irrigation / Sprinkler Forum
    Last Post: 08-09-2008, 10:38 AM
  4. Design Help
    By IceTreay in forum Irrigation / Sprinkler Forum
    Last Post: 02-03-2008, 07:15 PM
  5. DWV design OK?
    By lottia in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-05-2008, 07:16 AM
