Results 1 to 9 of 9
Thread: Pressure Reducing Valve: Bad?
    DIY Junior Member JohnnyO's Avatar
    Mar 2013
    Twin Cities, MN
    Default Pressure Reducing Valve: Bad?
    Reading up on household water pressure, it seems the 90-95 showing on my PRV is too high.
    I'm assuming the pressure shown as actually post-reduction, and not the street pressure, but I can't find any reference to this Wilkins Model 70 value that also shows the attached gauge, so I'm not positive.
    This was new about 5-8 years ago.
    Does this value need to be replaced, or should I try adjusting the valve via the screw, or is the pressure displayed actually the pressure BEFORE reduction?
    Thanks,
    John
    Mar 2013
    Twin Cities, MN
    Thanks for the link, Terry. That repair process looks very straightforward.
    John
    I would try adjusting it first. You can also pick up a gauge at a hardware store that works with your outside hosebib to check pressure too.
    DIY Junior Member fixitright's Avatar
    Aug 2011
    Minnesota
    What a nice tutorial.
    Wouldn't it be nice if more companies did this with their products?
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Yeah that gauge should be reading donwstream or house pressure. Looks like the bolt is tightened down a bunch. Try loosening off on the adjustment bolt.
    Mar 2013
    Twin Cities, MN
    I will try backing off on the bolt to see if it brings the pressure down.
    Thanks.
    Mar 2013
    Twin Cities, MN
    I ordered and received the repair kit. With that in hand, I did get a second gauge and connected it to an outside hose bib to double check the pressure. They matched (within 3-4 PSI). I adjusted the knob out about 1/2 inch, ran some water, turned off the water, and noted no change in pressure.
    Next step - do the repair kit. I think I'll wait to tomorrow for that.
    I appreciate the advice!
    John
    Mar 2013
    Twin Cities, MN
    PRV repair completed! [It took one borrowed big wrench for the bell housing and one purchased 1 1/8" socket for the cartridge removal, but other than that, it went smoothly.] Thanks for the guidance!
    Best of all - 6 hours after the repair, and no leaks!
    John
  1. Noise from Pressure Reducing Valve????
    By chuck0542 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2011, 08:48 AM
  2. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  3. Installing New Pressure Reducing Valve
    By gazaman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2010, 05:13 PM
  4. pressure reducing valve/relief
    By hidden 1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2009, 04:19 AM
  5. pressure reducing valve
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 05:45 PM
