Results 1 to 2 of 2
Thread: Southern Calif... Watts 210??
    Plumber jimbo's Avatar
    Default Southern Calif... Watts 210??
    As you may know, between medical disability, and desk job at a supply company for a while before that started, I have been " out of the loop" for field work for quite a while.
    Looking ahead to possibly needing to replace WH .... Is the Watts 210 temperature activated gas shut off still allowed in CA??? The place was built that way in '85, and I do have a pressure relief installed on the water supply outside the condo, inboard of the shutoff. Seems I have heard they may not be allowing that anymore.
    WH is in a closet of a second floor balcony. Balcony is weather-exposed. WH has a drain pan, so if we just ran a downtube into the pan, it drains through a tube out onto the deck. Would that fly? Condo assn. would not like to put a pipe thru the wall and down the side of the building.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    You would have to check with the AHJ. In San Diego,
    By the way that is the way I would run it a t&p with a drain into pan
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Watts 210
    By jimbo in forum UPC Plumbing Code Questions
    Last Post: 10-22-2012, 08:42 AM
  2. PVC drain pipe and fitting in Southern California?
    By Antonio4791 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2010, 10:06 AM
  3. Finding a heating system designer in southern NH?
    By NH Homesteader in forum Boiler Forum
    Last Post: 09-09-2009, 02:16 PM
  4. Southern California Water heaters $$$$$$
    By jimbo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2007, 02:54 PM
  5. Watts Exp Tank and PRV
    By Dunbar Plumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2006, 04:15 PM
