Thread: Delta 600 or 1600 series shower valve
    DIY Junior Member m@'s Avatar
    Apr 2013
    Chico, ca
    Default Delta 600 or 1600 series shower valve
    I have a shower only set up and I think it must be a 1600 from all the research I have done but someone who has seen this before would know better. Is the only difference the 600 has the tub portion? THey both look the same otherwise to me. Can I use a 600 renovation kit to get the venitian bronze if it is a 1600 or am I stuck with replacing the whole thing?
    Apr 2013
    Chico, ca
    Wow thanks Terry. I couldn't tell for the life of me and I was pulling my hair out.
    The 1600 uses a rotary motion and you can only control the temperature with the handle. Yours is a 602, or similar, which controls both the temperature and volume with the handle.
  1. Replacement Delta 600 Series Valve
    By kissmine in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2010, 06:46 AM
  2. Delta 18 series valve question
    By susandoc in forum Shower & bathtub Forum & Blog
    Last Post: 08-15-2009, 04:52 PM
  3. Delta 600 series shower/tub valve
    By xyz1612 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2008, 02:55 PM
  4. leak in Delta 13 series shower
    By Bob in NH in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2007, 03:32 PM
  5. Problem with Delta 17 series shower valve
    By Keith B in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2007, 08:24 PM
