Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: I have no idea what's going on with my piping.
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default I have no idea what's going on with my piping.
    Ordered and received my softener, asked my buddy to come be an extra hand while I hook it up (he knows more about plumbing than me since I don't really know much at all :P), and he tells me that this bypass (i'm actually going to cut off the the valves (they're not threaded) and use the pipes to connect to the included bypass) isn't set up to soften all my water, just a few select faucets. Taking a look at it, i realize that i (still) have no idea what this bypass is actually doing. Not sure if he's right, so I figured I'd ask here.
    I tried to take some pictures and a video so people could see what I have going on and maybe help me. I really would like to do this myself, and know that, while I'm not nearly the most qualified person, i am capable of doing this, and want to do it, but until I figure this out I'm gonna be at a standstill. I may call a plumber to help me trace the lines, but would really hate to spend anymore money than I already have on this "project." If I go that route I'm going to be out a decent chunk of money and it'll take me a bit to save up for that. :/
    Here is the album of pictures I took of the area: album. Here is a video: video.
    If anyone could point me in the right direction, that would be amazing! Thanks in advance.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    If you turn the center gate valve off, any water that is still running is not going though the softener.
    Mar 2013
    Here
    Quote Originally Posted by mialynette2003 View Post
    I meant, what part of our water is that bypass attached to? Doesnt seems like its on the main line. I dunno.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    As stated above you should be able to close the center valve and then determine what faucets are serviced by the pipes at the by-pass. You could turn it off and see if the water runs at the kitchen sink, bath room faucets, outside faucets etc, etc.
    Mar 2013
    Here
    That is a solid idea. Maybe I shouldve thought of that in the first place. I feel like an idiot lol...
    Thanks guys!
    Nov 2005
    Central Florida
    Are you sure about that? Looks to me like if you turn it off, any water flowing has to go through the softener. That's why they call it a "bypass" valve. With the softener yet to be installed, though, turning it off will turn off the water that will go through the softener when it's installed.
    Nov 2010
    Ocala, Florida
    Right now the left and right gate valves are closed and the center valve is open (I persume). If the center is closed, water will be shut off to where ever it is going. Any water flowing is not going though that bypass so it will not flow through the softener. The actual "bypass" is the cross over pipe so if it were hooked to a softener with the outside valves closed and the cross over valve open, the unit would be on "bypass".
    Mar 2013
    Here
    Ok, so i closed the middle valve, and tested a bunch of faucets. Nothing seems to be happening. If closing that valve does stop water to those faucets, how long would it take to notice reduced/no flow? I thought it was pretty fast. Which means, this bypass isnt doing much at all lol.
    DIY Junior Member JohnnyO's Avatar
    Mar 2013
    Twin Cities, MN
    It is hard to tell from your photos or the video where the main water from the city connects into the copper in the room with the bypass valves. I'm starting to think that those three valves may NOT have been set up as a water softener connection.
    I'd recommend getting out a piece of paper and sketching out your water pipes, at least from the point where the main feed enters your house to the point where it starts to be distributed to to other rooms or floors. If you forget about the three valves, and instead ask yourself, "where can I insert something that will get to -all- of my water using devices (except, perhaps outdoor faucets)? where would that be in your drawings? Where would it be in your house? That is where you would need to insert the water softener.
    You may also want to tap off a separate line ahead of the softener to feed the kitchen sink (either as the sole cold water feed to the kitchen, or ideally, as a separate line to a separate faucet in the sink).
    In my basement, for instance, the main water pipe enters the room through the floor. The first three items in line are: a shut-off valve, a pressure reducing valve, the city water meter, then another shutoff valve. After that, I have a tee, with one arm going to non-softened outlets (outdoor faucets, kitchen sink, ice cube maker) and the other arm going to the water softener (with its own bypass valve) then to the rest of the house.
    John
    Mar 2013
    Here
    Thanks for the informative post JohnnyO!
    I will try doing that. It's a little messy up there but if I get in the crawl space I think i could do it.
    I'm beginning to think this may be beyond me. Not so much the learning how to solder thing, but finding the right place to do it and bypassing the outside lines and ripping apart the walls freaks me out. It might just be a ton of work. It's gonna suck forking out a few hundred dollars or more to a plumber, but I guess you gotta do what you gotta do. I'll probably just take my mind off it for a while, haha.
    What could that bypass valve be for? It turned off nothing!
    Nov 2005
    Central Florida
    It says "water softener hookup" all over it, but it may have been an afterthought, hooked into the main system after the house was built. In any case, you'll save yourself a lot of money by crawling wherever you have to crawl and making a good drawing of your plumbing. Any decent plumber will want that information, and if he has to crawl to find it, he'll be crawling at $100/hr or so.
    One thought: if you turn open either of the two "other" valves, does water come out? Can't tell from the pictures if they're capped off or open, ready to be plumbed out further. If no water comes out, this "softener loop" may be valved off upstream. Turn off the bypass valve, and see if water comes out either of the other two valves (or both).
    Also, if you turned off the valve and it did in fact control any downstream water, you'd notice the reduction in flow almost immediately at a downstream fixture.
    Mar 2013
    Here
    Quote Originally Posted by Mikey View Post
    Hmm...makes sense, thanks Mikey. Can't remember if when we tested it yesterday, we closed the middle valve before we opened the others. I'm almost 100% we did, though. In any case, when we opened either of the other valves water did indeed come out, under pressure.
    Though, I am positive that when I closed all the valves (well, the other two were already closed :P), I couldnt figure out which faucets were affected. Cold and hot water worked, and even the outside faucets worked (i tried the kitchen sink, the first floor and basement bathrooms, the basement shower, the laundry room, and an outside faucet.
    Nov 2005
    Central Florida
    Very curious. All I can guess is whoever hooked this up screwed up or was fiendishly clever. I love a good puzzle; looking forward to hearing what you find.
    Nov 2010
    Ocala, Florida
    If you close the center valve, one of the other valves should have no water coming out after you depressurerize and drain the pipes. This would be the soft water side of the system.
    Mar 2013
    Here
    Haha, don't worry, I will (eventually) get to the bottom of this! Just seems crazy to me. What other reason would there be for a bypass?!
    The way it's setup is still confusing to me. When I think of a proper setup, I think of the main line, then a line coming up (or down, or whatever direction you want) to the softener, then a bypass, then another line coming up (or down, or whatever direction you want) away from the softener, and then the main line again.
    Question: even if I was using the softeners bypass, I would still have to have a bypass in the main line so that the hard and soft water don't mix, right?
  1. Absolute Newbie wants to fix own Grohe 33 625 shower faucet - good idea? bad idea?
    By plumbernotme in forum Shower & bathtub Forum & Blog
    Last Post: 12-18-2011, 05:23 PM
  2. Any idea what this is?
    By ToolCollector in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 06:15 PM
  3. Removing tub drain from septic system, good idea or bad idea?
    By Briandl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2010, 06:19 PM
  4. No Idea
    By Alaskansummers in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-06-2009, 06:00 AM
  5. any idea????
    By mikee in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2005, 10:40 PM
