Results 1 to 9 of 9
Thread: Kohler K-3810 Santa Rosa one-piece toilet. Pictures and Comments. Class 5
    Default Kohler K-3810 Santa Rosa one-piece toilet. Pictures and Comments. Class 5
    Kohler has the new Santa Rosa 1.28 GPF toilet. It comes with comfort height, which also makes it an ADA toilet with the seat. It's a compact one-piece bowl, good if you have a small space and want an elongated bowl. Install was good out of the box. I installed this at Sue's place, and it seems to be working well. It has Kohler's Class 5 flushing.
    Below are pictures.
    From the front
    The trapway
    Trip lever
    Kohler's flush canister and a Fluidmaster fill valve.
    With water in the bowl.
    27-3/4" long front to back
    Brand New Plumber GoKohlerGo's Avatar
    Aug 2012
    Michigan
    Looks pretty cool. I saw one today at L***'s and wondered what it would be like if it was installed. I have always wondered how you would replace the flush valve on a one-piece toilet if you needed to, since I don't have much experience with one-piece toilets.
    Am now a plumber! GoKohlerGo!
    DIY Junior Member susanna's Avatar
    Jun 2009
    Denver, CO
    Hi Terry!
    Can you tell me what the differences are between the various Santa Rosa's by Kohler? Are they all about the same quality now? I saw a previous thread with concerns about 90 degree turn that could cause problems with flushing. Has that been corrected on all models?
    Also, I want Toto Ultramax like my last toilet, but hubby says it isn't in the budget for our new house. (It also had a problem with some splashback and it used to leave some nasty stuff at the back of the toilet that had to be wiped off.)
    Lastly, I need 2 of the one piece toilets to have right hand trips. Do you know of a one piece that would have that option? If not, what 2 piece toilets might have the option?
    Susanna
    Just look at the picture of the side of the toilet...it speaks for itself...straight across the bottom, then 90 to the drain. Now, most stuff you flush is somewhat flexible, but longer, harder deposits may just not make it around that sharp corner...everyone's different, but it certainly will slow things down - stuff doesn't like to make 90-degree sharp bends.
    Apr 2012
    New York, NY
    You're going to pay around $100 more for the Ultramax II than the Santa Rosa, but if you shop around, that's all you're going to pay. I would get on the horn to the plumbing supply places in the yellow pages, give them the exact model number you want, and horse trade a bit. Then maybe you can have your Ultramax. The II version should do better than the original at some of the things you mention, and it's ADA height, comes with Sanagloss as standard equipment, uses the Double Cyclone flush, and only uses 1.28 gpf so it qualifies for a Watersense rebate if they offer that in your area.
    Moreover, the Ultramax II DOES offer a right-hand trip lever. The model number would be: MS604114CEFRG. That differs from the regular model number by the addition of the "R", standing for Right Hand Trip Lever (right hand as you are looking at the toilet; left-hand if you are sitting on it.) The right-hand trip lever option is only available in the Cotton White color on the Ultramax. The normal trip lever version is available in the usual 5 colors.
    If you want something that has a street price similar to the Santa Rosa, you could look at the Drake II. I think it is quite stylish, and it has all the features of the Ultramax II that I mention above, except it is a two-piece and looks a little different than the Ultramax. It is one of the most popular toilets out there. CST454CEFG. It is available in a right-side trip lever version in Cotton White only for essentially the same price: CST454CEFRG. Again, you add the "R" to the model number. The left-hand trip lever one is available in Toto's usual 5 colors.
    And of course the workhorse Original Drake (of which we have two) is available for at least $100 less than the Santa Rosa, works like a champ, and is available with a right hand trip lever. CST744S (1.6gpf) or CST744E (1.28gpf). The original Drake with the right-hand trip lever is available in all these colors: Cotton White, Colonial White, Bone, Sedona Beige and Ebony (black). CST744SR or CST744ER
    So if you want a right-hand trip lever in a toilet in a color, then the original Drake is one great option.
    Hope this helps!
    Kohler now lists two versions on their web site,
    Standard height elongated
    ADA height elongated.
    They look to have the same parts in the tanks, and the bowl and trapway design are similar.
    I had posted pictures of their old Ingenium Santa Rosa before, but that model has been replaced by the Class 5 version.
    DIY kid who loves toilets Starwarsith88's Avatar
    Aug 2013
    Sparta NJ
    This a response to gokohlergo with a question about the flush valve replacement on a one piece toilet, with a one piece toilet, you would have to do the job inside the tank. Hope that helps!
    If you need to go with a new toilet, go with a TOTO!
    I just installed this Santa Rosa in Medina for a customer.
    They opted for the slow close seat upgrade.
    Aug 2013
    Sparta NJ
    Nice looking toilet!
  1. Kohler Tresham K-3950 toilet, Reviews, Pictures and Comments
    By Terry in forum Toilet Forum discussions
    Last Post: 02-16-2013, 01:27 PM
  2. Kohler K-3386 Rialto One-Piece Toilet, comments and pictures
    Last Post: 09-25-2011, 05:29 PM
  3. Kohler Santa Rosa toilet product review, K-3323, Ingenium Flush
    Last Post: 08-05-2011, 05:42 AM
  4. bidet for kohler santa rosa / k-3323
    By chandler in forum Toilet Forum discussions
    Last Post: 01-02-2011, 12:56 AM
  5. Toto Ultimate MS854114 versus Kohler Santa Rosa
    By monkey in forum Toilet Forum discussions
    Last Post: 08-22-2005, 12:44 PM
