Results 1 to 8 of 8
Thread: fluid dynamics - constrictions in gate valves
    DIY Junior Member tbb2's Avatar
    Feb 2009
    Arlington, Virginia
    Question fluid dynamics - constrictions in gate valves
    This is something that nags at me whenever I install a gate valve.
    If I have a 3/4" copper supply that goes into a gate valve the valve body cuts the pipe ID in half (or more).
    Why isn't there a drop in supply pressure on the outgoing side of the valve?
    Or is it that the difference isn't obvious?
    If it is that the difference is not obvious then why do I need 3/4" when the valve is only allowing 1/2" at best to pass thru it (don't add a 1/2" gate valve into the discussion) ?
    Or is this just why I like ball valves?
    Venturi effect...personally, I do like ball valves since it's rare the seals go bad and the connection to the gate doesn't break.
    Pressure is not affected by reducing the size of the pipe (valve). Flow can be affected, but when it's just a short distance like the valve, it would be hard to measure. As Jim notes above, ball valves are a superior valve.
    FWIW, a ball valve doesn't work all that well as a throttle, works better as an on/off valve. Normally, though, that's what you want with a supply valve.
    DIY Member BillTheEngineer's Avatar
    Jan 2011
    Smithtown, NY
    You are probably not seeing a drop in flow or pressure through the gate valve because you are not at the limits of the valve. There is a drop in pressure through it but it is small, maybe a 1 to 3 psi at the highest flows you are putting through the valve. A gate valve has a pretty unrestricted path only sightly less than a ball valve.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Another way to look at it (a pretty good approximation at reasonable flow rates) is that a restriction like a valve is equivalent to some length of the pipe you are using. The same goes for fittings...
    You are buying "cheap" valves, '(but who uses gate valves any more in the first place)? ALL the good ones are "full port" which do NOT have the restriction. IF you were to use a Jet-Swet, or similar stopper, to add or change a valve, you would need a full port valve or you would not be able to extract the stopper through the valve.
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    I agree with HJ. use FULL PORT ball valves. If you are using them in a sweat copper system use threaded valves and use male pipe thread adapters. If you plan to insulate around the ball valve find a brand that has the handle extended up from the top of the valve. The extended shaft is enclosed in a plastic tube so that you will only need to cut a small hole in the insulation. Otherwise ball valves are difficult to insulate. If you were installing a chilled water piping system in an area of the country where humidity is high they will sweat quite a bit.
  1. Laundry room gate valves messed up
    By a12548 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2011, 08:35 AM
  2. fluid master 7500
    By danl02026 in forum Toilet Forum discussions
    Last Post: 12-27-2009, 09:07 AM
  3. Adding a WH to Thermo-Dynamics S-85 boiler
    By rcicu in forum Boiler Forum
    Last Post: 12-17-2009, 10:52 AM
  4. Fluid Master 400a Loud
    By rldev in forum Toilet Forum discussions
    Last Post: 01-13-2009, 05:24 PM
  5. Washer fluid leaks
    By mrashirley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-17-2005, 03:54 PM
