Thread: Shower Valve Flow Rate
    DIY Junior Member Bob C's Avatar
    Mar 2013
    Central PA
    Default Shower Valve Flow Rate
    I am remodeling my shower. I have a Danze shower valve. I looked down into the outlet of the valve and it appears that the water will be actually flowing through a hole that is about 3/16 dia inside the valve. Is this right?? What flow rate should I get through the valve?
    That spec should be on the spec sheet for the specific valve. Depending on the design, smaller orifices in a valve may or may not present a huge restriction...while it slows the water down, if the narrowing insn't too long, it speeds up going through, and then slows down on the outlet, keeping the flow rate similar to not having the restriction at all...all depends on how short and careful the deisgn is. Look up the venturi effect.
    Now, if this is only feeding a single showerhead, it may easily supply the water to the head - all today are restricted to 2.5gpm max (at a certain supply pressure - yours may be lower, and you'd get less).
    The manufacturers do not really have to worry about the size of the port in the valve, because the shower delivery is capped at 2.5 gpm, regardless of where the restriction occurs.
  1. Toto shower valve flow rate performance video
    By lifespeed in forum Shower & bathtub Forum & Blog
    Last Post: 07-02-2012, 09:43 PM
  2. adjust flow rate on Symmons safetymix'ette' series II shower valve
    By mdschomburg in forum Shower & bathtub Forum & Blog
    Last Post: 10-16-2011, 03:57 PM
  3. Shower Valve Supply Confusion - GPM/Rate of Flow
    By Erc in forum Shower & bathtub Forum & Blog
    Last Post: 04-15-2011, 10:41 AM
  4. Newbie question... how to measure flow rate of a shower?
    By SliderJeff in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2009, 05:53 AM
  5. Replies: 1
    Last Post: 09-28-2005, 08:07 PM
