Results 1 to 2 of 2
Thread: Delta 600 series hairline crack?
    DIY Junior Member 747flyer's Avatar
    Apr 2013
    Littleton, NC
    Default Delta 600 series hairline crack?
    Hi, I have an older shower/diverter Delta 600 series shower assembly. While tiling, I had to move the valve body backwards to adjust how much of the stem was sticking out for the new trim. Now with the thing back together, and a new Delta repair kit installed, I still get a drip off the valve body itself, somewhere near one of the mounting ears on the bottom. Is it possible I have caused a hairline crack somewhere in the valve body itself: And, can it be soldered if I can find the crack? Thanks for any helpful reply's.
    It is more likely a problem with one of the three small tubes connecting the two pieces together. If so, it CAN be done, by taking it apart, but it is not a job for an amateur, since even professional plumbers call me to fix the valves for them.
  1. Replies: 8
    Last Post: 02-25-2013, 06:01 AM
  2. Replacing a Delta 1300 series with a 1700 series
    By desvio in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2011, 06:42 AM
  3. Hairline crack in Bathroom Ceiling....HELP
    By Chris in Calgary in forum Remodel Forum & Blog
    Last Post: 04-02-2008, 04:53 PM
  4. hairline crack in new sink
    By Heyworth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2007, 05:24 PM
  5. Hairline (almost invisible) crack in Toto bowl
    By JASchneider in forum Toilet Forum discussions
    Last Post: 07-22-2005, 09:44 AM
