Results 1 to 4 of 4
Thread: System Pump Suddenly Louder.
    Default System Pump Suddenly Louder.
    I have a Burnham Alpine 150 with a Taco 0014-F1 as the system pump on the primary loop as spec'd in the install manual. The pump is approximately 2 years old. In the past week or so the pump has become louder. It sounds like a buzzing that is consistent and is louder than all 4 Taco 007 zone pumps that I have combined when running.
    I took the pump out and disassembled it thinking maybe something was stuck in it or that the cartridge in it had gone bad already but found nothing. No foreign matter or play in the impeller shaft.
    Any other ideas on what would be causing the problem? I don't want to buy a $140 replacement cartridge if it isn't the answer.
    Mar 2011
    Houston, TX
    It could be the capacitor.
    It might be worth testing.
    It should be 14uf 250VAC.
    Good Luck.
    I took the pump apart again. There was some scuzz clogging the fins of the impeller on one side causing the whole thing to be unbalanced when rotating. I cleaned it up and put it all back together. Now it runs pretty much silently.
    Mar 2011
    Houston, TX
    Quote Originally Posted by mage182 View Post
    Nice work.
    It is great that you got it working properly.
    Enjoy.
  1. no water for Christmas, please help! well pump suddenly not cycling
    By moray in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-27-2012, 03:08 PM
  2. Replies: 3
    Last Post: 01-03-2011, 01:29 PM
  3. Toto Drake louder than expected
    By Kneauxdn in forum Toilet Forum discussions
    Last Post: 01-22-2008, 10:03 AM
  4. well pump suddenly stopped working-why?
    By PeteHog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2006, 11:08 AM
  5. Suddenly - no water
    By robbie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-10-2006, 10:13 AM
