Results 1 to 4 of 4
Thread: relocating toilet/shower on concrete slab
    DIY Junior Member GatorKenD's Avatar
    Aug 2010
    Gainesville, FL
    Default relocating toilet/shower on concrete slab
    Hi - I'm at the planning stage on remodeling two back-to-back bathrooms. In the small "south" bathroom, I want to put a tub in where the toilet is currently located (marked "A") and move the toilet to where the shower currently is ("B"). Below is a closeup of the plumbing plans for this space. The house is a 1979 north-Florida home on concrete slab (and I'd like to minimize how much concrete I have to remove!) The roof of the house is also concrete so I'm hoping the existing vents are adequate as additional roof penetrations would make this a lot more complicated. I'm looking for suggestions as the most straightforward way to reconfigure this. Thanks!
    KenName:  bathroom plumbing2.jpg
    IF the pipe is installed the way you show it, then removing toilet "A" would make the vent at the other toilet "legal". Your current shower drain is NOT "legal" the way you show it, and putting the toilet connection there would also be improper, unless you add a vent for it. The shower needs a new connection so you can put it anywhere you want to, as long as you vent its trap.
    Aug 2010
    Gainesville, FL
    Hey hj - The drawing was the original architect's plan. I suppose its possible (and maybe likely) the plumber vented the shower correctly when he did the work (B). I attached a revised drawing so that I could ask some additional questions. I know some of this is "what if" but I want to have a plan (and some Plan B's and C's) in mind before I jump in. Some more specific questions:
    1) For a house built in 1979, is it likely the toilet drain is 3" and the shower drain 2"? Can I tell without busting slab (i.e., is the diameter of the trap pipe likely the same as the shower drain?)
    2) I want the new tub drain located at point E. Any reason I can't tie the trap under the tub to the old toilet drain at point A? (keep in mind I've got another toilet on that drain in the north bath... sure don't want what's going into the north toilet coming up the south tub!)
    3) I want the new toilet drain located at point C. If the old shower drain is 3", any reason I can't use the old shower drain? (again, assuming that there is a vent for the old shower or I install one at this location now.
    4) If the old shower drain is 2" and I can't use it for the toilet, can I tie in my new toilet drain (C) into the old one at point D? (in an effort to avoiding taking up any more slab than I have to)
    Ken
    quote; The drawing was the original architect's plan
    In that case it probably does not have any correlation to the actual installed piping. The plumber would have installed it the way HE wanted to.
    1. It is very likely that they are those sizes.
    2.You CAN connect the tub anywhere you want to, BUT, it must have the proper venting, which it would not have if you just connect the trap there, besides, to do so would almost require that you create an "S" trap.
    3. It will NOT be so don't even get your hopes up.
    4. No, or rather, ONLY if you vent it properly. As shown, it does NOT have a vent.
  1. Opening slab - relocating shower drain-help
    By Remodelboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-28-2008, 08:46 PM
  2. New Shower Drain in Concrete Slab
    By smithy1023 in forum Shower & bathtub Forum & Blog
    Last Post: 03-27-2008, 12:21 PM
  3. Shower Drain In Concrete Slab
    By navyboy98292 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2006, 09:40 AM
  4. Help! leaking Shower on concrete slab
    By patchen777 in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2006, 08:39 AM
  5. Relocating Toilet on slab eeekk
    By gdunbar in forum Toilet Forum discussions
    Last Post: 06-28-2005, 11:01 AM
