Results 1 to 8 of 8
Thread: Curbless shower rough in
    DIY Junior Member C Williams's Avatar
    Jan 2012
    Vancouver Island
    Default Curbless shower rough in
    Im at the point of under slab rough in and looking for some advice before we pour the house slab.
    Im wanting to construct a curbless shower stall (54x36) and wondering what my best approach would be. The finishing in the bathroom will be the acid etched concrete slab with a tiled shower area. Is it common and would it make sense to recess the concrete in the shower area by X inches to accommodate a shower floor system like Kerdi Pan etc.? If so, what should X be.
    I can also see a time in the future where someone might want to convert this space to a bathtub/shower but jackhammering up the floor would be ill advised since it will have radiant heat pex embedded in it.
    So the next question is where/how should locate the shower drain such that, at some time in the future one could easily utilize the existing drain for a tub. I guess Im looking for a rough in procedure that would be suitable for both. A linear shower drain would also be nice but that might complicate things and its probably outside of my snack bracket.
    Thanks in advance.
    Jul 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
    Jan 2012
    Vancouver Island
    Quote Originally Posted by johnfrwhipple View Post
    At concrete placing time you do not want to be building a piano. A simple 2"x4" form will do the trick.
    Love it!
    Thanks John, My slab is only 4" thick so I guess I could just forgo the concrete in the shower area and just leave exposed Insulation. What about drain rough in? Just box it in like a normal tub?
    You want the recessed slab to be of comparable thickness, so it will take some rebar bending and a depression in the slab there to keep things monolithic. You do not want the new shower pan to be floating from the existing slab or bad things will happen. My unprofessional opinion...you're just asking for the tile to crack over the transition into the main slab.
    Jan 2012
    Vancouver Island
    Thanks Jim, Excellent point.
    Jul 2009
    North Vancouver, BC
    DIY Junior Member Wilson22's Avatar
    Apr 2013
    BC
    Thanks John,
    The perimeter drain is 20" below the slab height. Have I decide on the drain I want? Nope. Tile layout? Nope. Waterproofing system? Nope. Show size? 36"x 64"
    Perhaps I need to know to much of the finished details to have a curbless shower.
    Jul 2009
    North Vancouver, BC
  1. curbless shower
    By tucker2 in forum Shower & bathtub Forum & Blog
    Last Post: 02-10-2014, 02:04 AM
  2. My curbless steam shower project
    By kholsme in forum Shower & bathtub Forum & Blog
    Last Post: 05-03-2013, 04:39 AM
  3. Curbless Shower
    By Freddie in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2013, 01:56 PM
  4. ADA Curbless Showers in a Residence
    By PA Tile Guy in forum UPC Plumbing Code Questions
    Last Post: 07-18-2011, 05:01 PM
  5. bath remodel curbless shower layout
    By grymes56 in forum Shower & bathtub Forum & Blog
    Last Post: 02-08-2010, 07:14 AM
