Results 1 to 4 of 4
Thread: Shower stall replacement
    DIY Junior Member brussell222's Avatar
    Apr 2013
    Easton Md
    Default Shower stall replacement
    I want to replace my shower stall. My current shower unit measures 46" wide. I can only find 48" units. I'm not sure I can find 2 extra inches when I remove the old unit. Has anybody run into a similar situation
    any ideas?
    Jan 2008
    A shower can be made any size.
    If you want to buy a shower stall from a store, you have to chose from what they sell.
    DIY Junior Member dvddiva's Avatar
    Mar 2013
    Ontario
    If you would consider going a little smaller,you might want to try showers by Maax.
    I'm pretty sure that shower kits are measured the same way tubs are...from the rough-opening. You sure it's 46"? That being said, you can make or have made a tiled shower in any size as you wish (as long as it's above the code minimum 30x30" in the USA).
  1. Is shower stall ceiling lighting required in a new renovation shower?
    By GGB in forum Shower & bathtub Forum & Blog
    Last Post: 05-07-2012, 05:13 PM
  2. Bifold Shower Door For Stall Sized Shower 40.25" Wide
    By turbocruiser in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2011, 04:57 AM
  3. Replacement Glass Shower stall seals
    By Jimgoli in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2011, 01:09 PM
  4. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  5. Turning walkin shower stall into bathtub/shower combo
    By Brian_Houston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2005, 05:13 PM
