Results 1 to 6 of 6
Thread: Strange problem with Glacier Bay Kitchen faucet
Hybrid View
    DIY Junior Member juriggs's Avatar
    Apr 2013
    Littleton, CO
    Default Strange problem with Glacier Bay Kitchen faucet
    Whenever I turn on my shower, my kitchen faucet begins leaking. It's not just a drip... it's a stream of water. This is just the hot water... if I turn on the cold water, nothing happens. Also, it doesn't happen in reverse... if I turn on the kitchen faucet, no leaking from the shower head.
    Any help would be appreciated. I'm selling this house, and want to resolve this before closing.
    Thanks,
    Justin
    WE would have to know the make and model of the sink faucet, so we could decide IF a drop in pressure could activate it. Does the "flow" stop when you turn off the shower, or do you have to do it yourself? Is the faucet mounted to the wall or on the sink?
    Apr 2013
    Littleton, CO
    The sink is a Glacier Bay model number F8FA0000BNV. The leaking stop when we turn off the shower, But I should've mentioned that it starts when we have the washing machine on as well. The faucet is part of the sink not mounted to the wall.
    Thanks for the help!
    DIY Junior Member Seattle2k's Avatar
    Nov 2012
    Seattle
    Glacier Bay....check the cartridge and seals. I'm guessing a low-flow showerhead is causing the shower's hot water to feed over to the cold line, of vise versa, and the increased pressure in that line is backing up to the point of least resistance, being the crappy Glacier Bay faucet.
    IT has a ceramic disc seal so it should NOT "separate" when the pressure changes. Since it does, you need a new valve insert.
    Apr 2013
    Littleton, CO
    Thanks, I'll try that and report back
  1. Glacier Bay Glacier Bay Dual Flush HET AIO Toilet
    By bighornram in forum Toilet Forum discussions
    Last Post: 09-11-2013, 01:40 PM
  2. Need help Removing Stem Glacier Bay 728-075 Faucet
    By raj49 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2010, 03:14 AM
  3. strange kugler faucet problem
    By zinc7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2010, 07:10 PM
  4. Glacier Bay lav faucet
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2009, 02:54 PM
  5. kitchen faucet strange problem
    By dodcar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-04-2007, 09:15 PM
