Results 1 to 10 of 10
Thread: Water service upgrade for home fire sprinkler
    DIY Junior Member mattster1975's Avatar
    Apr 2013
    TX
    Default Water service upgrade for home fire sprinkler
    Hi:
    I am looking at installing a home fire sprinkler in a 2 story slab home.
    The current water service is only 5/8" and the sprinkler contractors have advised that is not going to be big enough.
    Is it possible to replace the existing water service to and inside the the house with a 1" service, or does it make more sense to either
    1. get a separate dedicated meter for the fire sprinkler and have it enter the house above grade (with insulation)
    2. have a 1" meter installed and then have that line tied into a new sprinkler line and existing domestic water line in a valve pit (with shutoffs and backflow preventers as requires) and then have the 1" line enter the house above grade.
    (the shutoff for the sprinkler will be at the meter and inside the house locked open I believe).
    Any tips generally on retrofitting these systems is appreciated.
    thanks!
    Plumber jimbo's Avatar
    First ask the water company about costs. You pay an meter fee based on size. But the water RATE for sprinkler system may be different, so it may pay for it to be on a separate meter
    Depending on the sprinkler head type, design, quantity, and their placement, 1" may not be sufficient. One condo near me made up of townhouses needed 2" service per each unit. They all complain about their water demand charge. Many utilities charge by how much water you COULD use in addition to how much you DO use.
    DIY Junior Member Dominick G Kasmauskas's Avatar
    Apr 2013
    New York
    Look into Tank and Pump options. Tank required to hold enough water for 10 minute fire flow. Generally around 300 gallon tank, not very big. Pumps can be electric or there are a couple manufacturers that have non-electric pumps that run by stored CO2 or Nitrogen cylinders or air compressor.
    May be less costly than worrying about underground, meters, backflow prevention, and ridiculous fees for fire sprinkler systems.
    Apr 2013
    TX
    I am thinking about tanks too. I was leery of the tank because of the reliance on the electrical grid, but if there are non electric pumps that makes it more interesting. Mostly I want the sprinklers to give me a few more min to evacuate if there is a fire so a 10 min run time is ok.
    The other part of the project is the whole pipe install in the house. There are options about where to run the pipe - I have floor trusses so I am thinking it is best to put the pipes in the ceiling (and either cut the ceiling drywall or pull up the carpet and go in from the 2nd floor. It is possible to run the pipes along the wall ceiling junction and conceal with molding too. I'm just not sure the best way to go an the sprinkler guys either won't touch any drywall, or will just do rough demo.
    There is no water flow through a sprinkler system unless there is a fire, so the majority of them are connected to the house line. In fact, some systems are being installed as part of the house plumbing system rather than having their own piping. I once asked the fire marshall why they connected the fire line AFTER the house valve, since that made it ineffective if the homeowner shut off the water for a vacation, for example. He said, "If the water is turned off, there is probably on one in the house. Our fire sprinklers are to save lives, so if no one is in the house, we don't care if it burns down."
    Apr 2013
    TX
    Yes - if I was building a new house I would probably do a system like this (UpHonor makes a PEX system that works with domestic water). The only risk would be if the whole house was shut off and we were sweating in a water heater and started a fire that way (but this would be during the day anyway when fire risk is lower and it's easier to get out etc).
    Texas has a program for plumbers where they can take a continuing ed class and get certified to install residential sprinklers though I'm not sure how many folks are doing this.
    I think my current water supply is not adequate though for a fire sprinkler system (it is only 5/8" line and I am not even sure where it comes into the house).
    In another 10-years, sprinklers in new construction may very well be a universal thing in the USA...it's being enforced in some locales now and expect it to spread. Often, a fire only starts in one room, so you may not need a lot of water to put it out if the sensor turns it on fast enough. In some cases, seconds count. In some, it could smolder for a long time before it might generate enough heat to trip the thing. Getting proper coverage with the flow and pressure you have is critical to a full-coverage system. Expect more choices as these become mandated and the sales volume goes up in the future.
    Apr 2013
    TX
    A lot of newer construction is done with light weight construction (floor and roof trusses and wood I-beams etc) and it seems that this style of construction does not perform as well in a fire when compared to traditional construction with larger dimensioned lumber. Houses built with lightweight construction have structural failure sooner in a failure making sprinklers for these kind of homes more important.
    quote; The only risk would be if the whole house was shut off and we were sweating in a water heater and started a fire that way
    The way most domestic fire systems are connected, it would be shut off any time the house valve was closed, such as installing a water heater.
  1. Service Upgrade completed!
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 12-12-2011, 11:44 AM
  2. service riser needs for an electrical service upgrade?
    By myladyfae in forum Electrical Forum discussion & Blog
    Last Post: 02-22-2010, 11:28 AM
  3. House Fire Sprinkler
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2008, 01:43 PM
  4. Upgrade to 120 amp service without rewiring?
    By mckern in forum Electrical Forum discussion & Blog
    Last Post: 08-08-2008, 08:18 PM
  5. Need Help with Fire Sprinkler system
    By DonM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2007, 03:35 PM
