Results 1 to 5 of 5
Thread: minimum drain pipe size for a lav
    DIY Junior Member poky1234's Avatar
    Dec 2012
    Woodbridge Ontario
    Default minimum drain pipe size for a lav
    Hello, Can someone tell me if an 1 1/4 pipe can be used to drain a lav? The drain pipe would run 4 to 5 feet ,then connect into the vertical 3 inch main waste stack. Also , because of the short distance,would it still require its own vent?
    Jan 2008
    In the U.S., the trap and trap arm of a lav is commonly 1-1/4", but the drain is run in 1-1/2".
    From the International Plumbing Code (IPC)
    The lav should have a vent before it enters any "waste" stack.
    A lav can wet vent a shower, tub or toilet, but you can not run down waste on top of it in that manner.
    it can be 1-1/4" drain and can be stack vented if there is no discharge upstream of where it connects to the 3" main. If there is discharge from above that connection then it does require tis own separate vent
    Dec 2012
    Woodbridge Ontario
    Quote Originally Posted by mikeplummer View Post
    Thanks for the replies guys. Mikeplumber, that is exactly what we are doing. I just needed to know if 1 1/4 is ok. This is for a custom floating boathouse that has very tight quarters and is a little unconventional. I have another question but I'll post it with a pic and drawing.
  1. What is the minimum slope required for horizontal toilet drain pipe?
    By Hjgmvca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2012, 05:44 AM
  2. minimum size for washing machine fixture
    By mmmm in forum Canadian Plumbing Code Questions
    Last Post: 10-27-2010, 02:54 PM
  3. Drain pipe size
    By DMP in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2009, 06:27 AM
  4. Codes minimum size and opinion
    By willl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2008, 06:10 AM
  5. Minimum pipe size for a toilet vent?
    By lahabra in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-23-2007, 02:38 PM
