Page 4 of 4 FirstFirst 1234
Results 46 to 60 of 60
Thread: Help installing toilet flange
  1. #46
    Apr 2012
    New York, NY
    WHOA, Guys!! I read Jim's comment about the "toilet fitting" just to mean that you didn't want to keep running it into the heel inlet, not that he was saying that Terry's suggestion of a wye was wrong!! I don't think I have ever seen Jim purport to contradict Terry. In fact, he often passes on offering advice where it gets into codes and the technicalities of plumbing; indeed, he did that earlier in this very thread.
  2. #47
    So the advice of a working plumber is not good, but Jim the Retired Defense Industry Engineer's is.
    I can't tell you how many thousands of jobs I've had permitted and passed.
    All I said was you don't really want it going into the existing heel input...is that wrong?
  3. #48
    DIY Senior Member lordmoosh's Avatar
    Aug 2007
    USA
    Quote Originally Posted by wjcandee View Post
    You guys are being too serious. We were just JOKING. Jim is very helpful.
    Can anyone recommend good brands/models of AAVs? Any brands/models to avoid?
  4. #49
    Jan 2008
    The only one I have ever installed was an Oatey® Sure-Vent®.
  5. #50
    Aug 2007
    USA
    Hi all,
    I just finally got time to start doing this (finally almost done spackling/painting the bathroom...). I bought a donut as suggested by Terry and all. It is a 4x3 donut. Here is the one I got: http://www.homedepot.com/p/100201710
    The inner diameter of the cast iron hub is 3.75" and outer diameter about 4.5". The outer diameter of the donut is like 4.5". Did I purchase the wrong donut or am I missing something here? Thanks all.Name:  IMG_20130624_194821.jpg
Size:  52.6 KBName:  IMG_20130624_200337.jpg
Size:  39.1 KBName:  IMG_20130624_200346.jpg
Size:  37.4 KBName:  IMG_20130624_200428.jpg
  6. #51
    Measure the ID of the hub. Go to www.fernco.com and look up what you need.
  7. #52
    Aug 2007
    USA
    There is nothing on there website that I can find. I will try contacting them. Thanks.
  8. #53
    In looking at the picture...a donut will NOT work on this...it is NOT a hub! You need a reinforced connector to go from the CI to PVC. Essentially, you'd make connections as if it were the existing hubless CI, but need the connector to convert from the CI to PVC, which have different ODs. I think what you need is listed here http://www.fernco.com/plumbing/shiel...flex-couplings model 3000-33.
  9. #54
    Aug 2007
    USA
    Thanks I was going crazy with the donut. What is this "tee" called, a "no-hub" or "no-hub tee"? Wouldn't I need model 3000-43 which would be from 4" cast iron to 3" plastic?
  10. #55
    Drainage pipe is spec'ed as INTERNAL diameter...if the OD is 3.75, the ID is likely 3".
  11. #56
    Aug 2007
    USA
  12. #57
    Aug 2007
    USA
    Quote Originally Posted by lordmoosh View Post
    I did the plumbing today. The model 3000-43 was the correct item to use, it fit perfectly. One thing I'd like to ask you about. When I was measuring the pipe I had a 1/4" slope from the toilet elbow to the main stack. After I glued everything together I ended up with a 1/8" slope. It is about 1' between the toilet elbow and the main stack T. Do you think I should redo everything to get 1/4"? I poured water into the toilet drain and it went through without leaking.
  13. #58
    You're fine.
    Done, wrapped up, good to go.
  14. #59
    Aug 2007
    USA
    You're fine.
    Thank you all for your help!
  15. #60
    Yes, but he didn't have a hub, he has hubless CI, so the outlet of the Y is the same diameter as the rest of the pipe!
  1. Installing toilet with offset flange
    By Swetzel in forum Toilet Forum discussions
    Last Post: 11-01-2011, 09:39 PM
  2. Installing flooring & toilet flange
    By lucgallant in forum Toilet Forum discussions
    Last Post: 09-12-2011, 02:00 PM
  3. Installing toilet repair flange
    By Vega in forum Toilet Forum discussions
    Last Post: 01-04-2011, 05:56 AM
  4. Installing new toilet flange in concrete
    By alwaysfine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 01:18 PM
  5. Installing a toilet flange
    By kwhitt1017@yahoo.com in forum Toilet Forum discussions
    Last Post: 01-25-2006, 04:23 PM
