Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
Thread: Help installing toilet flange
  1. #31
    DIY Senior Member lordmoosh's Avatar
    Aug 2007
    USA
    We can only believe what you have told us, which is that the sink is not vented.
    I would not believe Terry's simple test of running some water into the lavatory because of the potentially low flow of the sink's faucet. You would need to drain a full sink or dump a bucket of water into it, and then check to see if the the trap has siphoned.
    If there is not a vent, it might be one of those times that an AAV will have to make do.
    Thanks I will try this test. Do I basically open the trap and see if its not full of water after draining the full sink?
  2. #32
    Jan 2008
    Yes. If the sink drain is without a stopper, you should me able to shine a light down the trap and see if it is full.
  3. #33
    When the waste exits the P-trap of the sink, and before it starts to go down, there must be a pipe coming off that arm within 42" for the size pipe you are using that goes up to act as the vent. Since it looks like the sink's drain just goes straight down in the wall, there MUST be a vent line going straight up from where it transitions from horizontal to vertical off the trap arm behind the P-trap, or it is an S-trap. Depending on the flow, you may or may not be able to siphon the trap in the sink, so the test is not definitive.
  4. #34
    Aug 2007
    USA
    The original plumbing was an s trap going through the floor connecting to the copper you see in the picture which is connected to the PVC. Doesn't this definitively mean the sink is not vented? In this situation would an acceptable fix be to run a p trap under the sink and attach an AAV and then drop the pipe through the floor? There are three load bearing joists under the wall behind the sink so there is no way I will be able to put a pipe in the wall and go down (or left or right or up for that matter due to other obstructions). Thank you.
  5. #35
    Some places allow an AAV, some don't. Having one is better than an S-trap. They can and do fail eventually, so they must be placed where they can be accessed. You want is as high in the cabinet as you can reasonably get it and still unscrew it to replace it.
  6. #36
    Aug 2007
    USA
    If I go with an AAV in the cabinet, does it make any difference whether I put a wye at the main stack or after the toilet elbow? Thanks.
  7. #37
    You don't really want to keep it into the toilet fitting, but I don't think it really matters which other choice you make once you've got the sink vented.
  8. #38
    Aug 2007
    USA
    I was looking at the stack pipe and have another idea. What if I leave the CI sanitee the way it is and use it only for the toilet and install a tee in the kitchen sink copper pipe you see in the picture below and connect the bathroom sink to the tee?
  9. #39
    Jan 2008
    I'm still wondering why you don't just vent the sink and cut the sink drain wye into the toilet waste arm, downstream of the closet bend?
  10. #40
    Aug 2007
    USA
    Because Jim said "You don't really want to keep it into the toilet fitting, but I don't think it really matters which other choice you make once you've got the sink vented." after I asked "If I go with an AAV in the cabinet, does it make any difference whether I put a wye at the main stack or after the toilet elbow? Thanks.".
    The "You don't really want to keep it into the toilet fitting" part made it sound to me like putting the wye after the elbow or "toilet waste arm" was not the best way to do it.
  11. #41
    Jan 2008
    The issue is the existing closet bend with the heel inlet. Getting rid of that and cutting in the wye is fine- as long as the sink is properly vented. If it is not vented, the sink's trap can get siphoned every time you flush the toilet.
  12. #42
    Aug 2007
    USA
    Ok, thanks!
  13. #43
    So the advice of a working plumber is not good, but Jim the Retired Defense Industry Engineer's is.
    I can't tell you how many thousands of jobs I've had permitted and passed.
  14. #44
    Aug 2007
    USA
    Hi Terry,
    Jim responded the fastest and has more posts than you. Clearly he must be at a higher level.
  15. #45
    Aug 2007
    USA
    I forgot to ask. I've read that there are cheap AAVs to avoid. What would be some brands/models that have a good track record?
  1. Installing toilet with offset flange
    By Swetzel in forum Toilet Forum discussions
    Last Post: 11-01-2011, 09:39 PM
  2. Installing flooring & toilet flange
    By lucgallant in forum Toilet Forum discussions
    Last Post: 09-12-2011, 02:00 PM
  3. Installing toilet repair flange
    By Vega in forum Toilet Forum discussions
    Last Post: 01-04-2011, 05:56 AM
  4. Installing new toilet flange in concrete
    By alwaysfine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 01:18 PM
  5. Installing a toilet flange
    By kwhitt1017@yahoo.com in forum Toilet Forum discussions
    Last Post: 01-25-2006, 04:23 PM
