Results 1 to 13 of 13
Thread: "Whole house filter"
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default "Whole house filter"
    What exactly is this referring to? My neighbor said he has one of these installed that goes before his softener. What exactly is it for?
    Feb 2011
    NW Ontario, Canada
    It is exactly as the name implies. It is a filter that all the water for the whole house goes through.
    Mar 2013
    Here
    But what particles does it filter out?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    It could mean carbon in a tank or inline filter with a replacable cartridge.
    Mar 2013
    Here
    Quote Originally Posted by mialynette2003 View Post
    He said its a little canister that i think is attached before the softener and it costs a few bucks to replace the cartridge every couple months.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by amateurplumber1 View Post
    It would depend on what particles are in the water to begin with, and what mesh or micron size the filter is. I have a 100 mesh filter that catches grains of sand and can be flushed so it is a permanent filter, not a disposable element.
    Mar 2013
    Here
    Oh, interesting, thanks for the info! What particles should I be looking for to judge whether I need a filter or not? How expensive are these things?
    Feb 2011
    NW Ontario, Canada
    Do you have a specific problem or is this a solution in search of a problem?
    Mar 2013
    Here
    Definitely solution in search of a problem lol. I figure if my neighbor has one there must be a reason.
    DIY Junior Member JohnnyO's Avatar
    Mar 2013
    Twin Cities, MN
    It is probably something like this: http://www.geappliances.com/products...filtration.htm
    Sediment, sand, rust, and chlorine are items that these filters can reduce.
    Take a look through the GE site for more info.
    Here is one type of filter insert that works in those devices.
    https://www.geapplianceparts.com/GEA...-filters-fxwtc
    John
    Unless you can see particles in a glass of your water, about the only reason to have one is to make the seller more money.
    Another down side is reducing the water flow for backwash and causing incomplete backwash and eventually ruining your resin. Then after a few years many people go back to the same dealer to buy new resin...
    A properly sized filter and appropriate maintenance can prove to be beneficial to your water quality and longevity of your softener. It is amazing what a pre-filter can remove over time. It is a low cost protection to your more expensive equipment.
    It was an INSIDE JOB!!!!
    Kinetico salesman Andy, he is talking a disposable cartridge filter. That's the type you guys usually sell when you can't get your softener customer to pay your high price for the Kinetico filter or combo filter/softener you propose.
  1. How to change the "BIG BLUE" carbon sediment filter???
    By rockandroller in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-04-2012, 05:43 PM
  2. Installing a "bottle trap" drain in an older house
    By boy412 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2012, 01:51 PM
  3. Matching Delta's "Venetian" Bronze finish and water filter systems....
    By single_digit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-18-2012, 11:43 AM
  4. Black "Soot" on Furnace Filter
    By Loocie in forum HVAC Heating & Cooling
    Last Post: 10-23-2008, 07:23 PM
  5. Can Pressure tank installation "fail" an Iron filter
    By 1erins in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-09-2007, 12:45 PM
