Thread: The grease/lube in Sharkbite fittings
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default The grease/lube in Sharkbite fittings
    What do you suppose the grease/lube in the Sharkbite fittings is for. To keep the O Ring from Drying out .
    I never realized there was grease until....from my previous project, in which I used a couple of SB caps while roughing out the room.
    Took off the caps, put them in a container for storage. Was just rummaging some stuff and came across the container of Sharkbites. Interesing....as all the grease had fallout.....and pooled in the bottom of the container, which caught my eye. I actually thought it was flux, ptfe, etc buildup from the pipes...and it had accumulated on the inside of the cap.
    Checked them out at Homers and there is clear grease on the bottom of these things..
    Jan 2008
    There has to be an MSDS available from the manufacturer. My initial guess would be a silicone-based grease.
    Silicone grease to ease the fitting sliding on to the tubing.
    The seal is o-ring(s). You want it to slide in place, not roll, possibly coming out of its groove. Lubrication allows that. Since it is rated for potable use, my guess is also that it's silicon based.
  1. under sink seal: To use lube/sealer or not?
    By Darto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2011, 06:37 AM
  2. SharkBite fittings
    By PEW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2009, 08:11 AM
  3. Sharkbite Fittings and old copper
    By AKRBT in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2008, 02:25 PM
  4. Sharkbite fittings?
    By smhowell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2007, 04:41 PM
  5. SharkBite fittings and CPVC and PB
    By bmkr94 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2006, 03:42 AM
