Results 1 to 6 of 6
Thread: Drip Irrigation Help!
    DIY Junior Member tsingh's Avatar
    Mar 2013
    hayward,ca
    Default Drip Irrigation Help!
    I put together a drip irrigation system that looks as follows.
    1 - From a garden spigot => small lead hose => multi connector manifold => timer valve (attached to an orbit timer) => 20 psi pressure regulator => pvc adapter => hose connector => 1/2 inch drip irrigation hose => connector => 1/4 inch drip irrigation tubing => 1/2 gph red drip emitter.
    2 - The half inch tube runs around the garden as follow
    26 feet straight (part 1) => elbow connector => 5 feet (part 2) => 30 feet straight (part 3).
    3 - I have for 1/2 gph emitters towards the end of part 1 and one sprinkler type emitter towards the end of part 3.
    When I turn the system on (I have the spigot turned on only ust a little bit), either manually or automatically for 1 minute..the 4 1/2 gph emitters are spraying a stream of water instead of dripping.
    What am I doing wrong?
    Here is a picture of the system.
    YOU can't do anything "wrong" with a drip system. Either the emitters need to be adjusted or they are defective, or they are designed to emit a "stream" in order to deliver that gph.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Are you using feed-through emitters, or end emitters?
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Another item is water pressure. ALL MY lines that come off of the house lines have one.
    http://www.dripirrigation.ca/wizard2...+the+next+step
    Kevin
    He has a flow control pressure regulator at the connection to the water line. The thing he DOESN'T have is a backflow preventer on the hose faucet, which is a universal requirement.
    Mar 2013
    hayward,ca
    Quote Originally Posted by bluebinky View Post
    Exactly the problem. THANK YOU!!
  1. drip irrigation
    By teamo in forum Irrigation / Sprinkler Forum
    Last Post: 07-18-2011, 07:28 PM
  2. drip irrigation for pecans
    By david u in forum Irrigation / Sprinkler Forum
    Last Post: 10-18-2010, 01:35 PM
  3. drip irrigation with 1/2" copper pipe
    By rati in forum Irrigation / Sprinkler Forum
    Last Post: 03-29-2009, 07:52 AM
  4. Need help turning on drip irrigation system
    By lgal63 in forum Irrigation / Sprinkler Forum
    Last Post: 05-29-2008, 12:27 PM
  5. Drip irrigation of groundcover
    By jdkimes in forum Irrigation / Sprinkler Forum
    Last Post: 07-01-2005, 06:33 AM
