Results 1 to 2 of 2
Thread: Leak under base of corner shower stall doors after cleaning, re-setting and caulking
    DIY Junior Member SuburbBeth's Avatar
    Mar 2013
    Long Island, NY
    Default Leak under base of corner shower stall doors after cleaning, re-setting and caulking
    I have corner shower stall (two stable panels and two sliding panels which meet in outside corner). The track which is adhered to the shower pan is curved at the outside corner. Professional brought in to remove doors fully, clean, and recaulk entire shower and stall doors.
    The water from shower still leaks at this outside corner (where doors meet). The leak slowly streams between shower pan and the 'set' aluminum base track (which was re-caulked inside and outside). It is a slow 'pool' which leaks out and onto tile floor.
    Is there a solution other than purchase new set of shower stall doors? Is there any solution?
    Is the entire pan set level? It sounds like it is not. There should not be any pooling, as the top of the curb where the door is attached should be sloped towards the drain. This won't be true if the pan is not set on a level surface, or it is not leveled when installed.
  1. No-Barrier Shower Base/Receptor/Stall
    By stephenson in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2013, 04:19 AM
  2. shower stall keeps leaking despite re-caulking everything
    By jenny8484 in forum Shower & bathtub Forum & Blog
    Last Post: 10-04-2012, 06:51 AM
  3. Best caulking for acrylic shower base
    By dirtmover in forum Shower & bathtub Forum & Blog
    Last Post: 11-08-2010, 05:11 AM
  4. Looking for good quality fiberglass/acrylic shower base and sliding doors
    By bases in forum Shower & bathtub Forum & Blog
    Last Post: 11-02-2010, 12:48 AM
  5. Setting shower base and tub base
    By myrightnut in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2006, 08:57 PM
