Results 1 to 15 of 17
Thread: 4 Gang Switch Box Wiring diagram
Hybrid View
    DIY Junior Member ChrisNJ's Avatar
    Feb 2007
    NJ
    Default 4 Gang Switch Box Wiring diagram
    Hey all. Other than my poor artistic skills, spelling and use of scrap paper does this plan look acceptable? This is a dedicated 15 amp circuit on a GFCI breaker (it's gonna be in a bathroom) straight from the panel using 14-2 NM. Black is hot, blue neutral, green ground.
    For the three 5 wire connections in the switch box, I was going to use Ideal 452 Wing Nuts in red for hot and neutral wires but I'm not sure if I can use those for the ground wire.
    As an alternative, can "rabbit ear" connections still be used rather than the 452 nut? Any suggestions or criticisms will be most appreciated. Thanks!
    Sep 2009
    Seattle. WA
    Ground wire (EGC) connections are no different than any other wire connections. Never heard of "rabbit ears", but if its a listed wire splicing device,
    and has the capacity for the number and size of wires,
    it should be fine. You need to ensure the switch device yokes are grounded, which may possibly require connection to the EGC.
    Feb 2007
    NJ
    Quote Originally Posted by kreemoweet View Post
    Thanks! Is it acceptable to pigtail the EGC to the 4 switches as long as I don't exceed each individual splice's capacity? For example:
    How's that look? Or do you have a suggestion? I'm all ears.
    Sep 2009
    Seattle. WA
    It's not only acceptable, it's required if you're using a plastic box. There are many ways to physically attach the wires, what you show looks fine.
    Feb 2007
    NJ
    Thank you so much for your help. I owe ya a beer
    The color of a "wire nut" is a function of its size and capacity. I have a feeling that you are going to run out of "box capacity" very quickly if you make ALL those spices you show.
  1. Please Critique My Wiring Diagram
    By eric3872 in forum Electrical Forum discussion & Blog
    Last Post: 02-04-2013, 07:22 AM
  2. Help with wiring diagram
    Last Post: 02-25-2012, 07:20 PM
  3. Cconvert 2 gang switch to 3 gang switch
    By soft in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2012, 03:17 AM
  4. Wiring diagram for bedroom
    By oxicottin in forum Electrical Forum discussion & Blog
    Last Post: 11-01-2010, 05:34 PM
  5. Wiring Diagram for Bathroom
    By nelsonba in forum Electrical Forum discussion & Blog
    Last Post: 12-03-2007, 08:28 PM
