Results 1 to 6 of 6
Thread: Galvanized RePipe- Tight Squeeze on Risers.
    DIY Junior Member JerseyShore's Avatar
    Dec 2012
    New Jersey
    Default Galvanized RePipe- Tight Squeeze on Risers.
    Progressing on re pipe of 1943 two fam... this is why I need PEX as opposed to copper for the risers. It is starting to get a little scarey. Check out stack in first pick. Very tight squeeze in there..... what to do about heating ducts???
    From what I can see, sweating copper risers should not be an impossible job. Certainly care would have to be taken to protect against fire by having a spray bottle of water within reach and flame guards to keep flame away from the joists. Guess you might have figured out that I'm not fan of PEX.
    I hope you do not think you can make a "square corner" by bending the PEX.
    Sep 2009
    Seattle. WA
    Nothing says you have to follow the route of the old pipes.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Although not a pro, I'm not a fan of PEX either.
    One thing to consider -- even though fewer joints is less to go wrong, you can always prefabricate sections before installation to get the in-place joints where you want them. For example, if you can get the riser out by undoing the union (background pipe in second picture) then you can get a copper section in just like it...
    Also, they make those fabric heat shields. If you can't afford that, even a couple layers of aluminum foil behind the joint can help some, with the added benefit that it will warn you by a noisy crinkling sound and melting just before the wood catches on fire. Have a good bucket of water and extinguisher handy.
    I have had good result soldering in tight quarters using a opened and flattened #10 can. Usually I cut a notch on one edge so I can slip it around a pipe and bend it a bit to get better coverage when needed. Not as fancy as the story bought fabric heat shield, but works fine.
  1. galvanized repipe to PEX
    By kadimkris in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2012, 02:28 PM
  2. Layperson needs advice on house repipe and old galvanized pipes
    By pinkoos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2011, 07:47 AM
  3. Toilet in a TIGHT squeeze...?
    By psolutions in forum Toilet Forum discussions
    Last Post: 10-01-2008, 10:03 PM
  4. What's more likely, shared risers or separate risers?
    By mckern in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2008, 08:00 PM
  5. Replacing galvanized in a tight space
    By Zach in forum Remodel Forum & Blog
    Last Post: 09-18-2005, 06:10 AM
