Results 1 to 2 of 2
Thread: Free standing basin style bathtub with no access to connect drain tail pipe trap
    DIY Junior Member dintraligi's Avatar
    Mar 2011
    Toronto Ontario Canada
    Default Free standing basin style bathtub with no access to connect drain tail pipe trap
    Hello.
    I've found many answers from this forum over the years so my thanks to all posters. This is my first time posting a question.
    I'm installing a free standing basin style bathtub. The abs drain/trap has been roughed in. The bathroom floor is finished/tiled and the room below the bathroom has a decorative ceiling and I was asked not to cut an access through it. Therefore, once the tub is in place there is no access to connect the drain (no access to tighten the trap adapter). Are there trap adapters that are friction fit using o-rings vs the common compression fit screw to tighten?
    Thanks in advanced
    Jan 2008
    You use a solvent weld trap and glue it up as you roll the tub into place. This is why you have to make sure everything is right the first time, because it's a one-shot deal.
  1. Drain For Garage Sink & Standing Pipe
    By Leaky1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2011, 08:36 AM
  2. Free standing laundry sink
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2010, 04:49 AM
  3. Concealed connections for a free standing tub
    By Ichthys in forum Shower & bathtub Forum & Blog
    Last Post: 04-17-2010, 08:47 AM
  4. slide in range swap out with free standing
    By augusta in forum Remodel Forum & Blog
    Last Post: 03-12-2009, 12:44 PM
  5. Absolutley no access to bathtub drain
    By lasparky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2008, 04:10 PM
