Results 1 to 15 of 15
Thread: gas stove supply line replacement
Hybrid View
    DIY Junior Member Mazcar's Avatar
    Jan 2013
    TX
    Default gas stove supply line replacement
    Hi All,
    I am trying to replace a 36" gas supply line for my stove with a 60" line.
    I just purchased a Brasscraft "Coated Stainless Steel Gas Connector" kit with a 5/8" OD in 60" length to replace the gas supply line for my stove.
    The instructions are a bit murky. So, I am hoping that some of the vets will provide some tips.
    When I removed the old hose from the stove and from the gas supply from the wall, I was left with a hose with two female ends. The new hose also has two female beveled ends, but included two adapters that made it have two male ends (non beveled). One of the two new identical adapters is shown on the edge of the stove in the second picture.
    When I unscrewed the hose from the stove, the old adapter stayed screwed into a gizmo that looks like some regulator or something. Should I leave it alone and use that old adapter with my new hose, for fear of damaging something by removing the adapter from that stove part? I did read a post where a guy cracked his regulator.
    If you tell me to remove that adapter and use the new one, how best should I prepare the adapter?
    I think that the instructions tell me to put pipe dope onto the adapter side that screws into the stove, but to not put anything on the beveled side that screws into the new hose. Is that correct? However, I did read on a post on this forum that I should avoid dope on the threads, but to put a little on the actual beveled surface. Is that correct? If I just use the adapters already screwed in place, do I clean the threads with a scotch-brite pad or with acetone?
    I have pretty much the same questions regarding the connection at the gas valve at the wall. When I removed the old hose, I saw what appears to be a high quality looking brass male connector at the end of the gas valve coming out of the wall. I suppose I could remove that adapter and replace it with the new one from the kit, but the male adapter at the wall looks like it has been doing the job for the last forty years. Should I just leave it alone? It is a beveled edge male connector that would match perfectly with my new hose's beveled edge female connector. Would I use NO pipe dope there?
    Everything was pretty freakin' tight. Is that the correct torque specification?
    So, in summary, should I replace ONLY the hose and reuse the adapters that are already screwed in place, clean the threads really well, and only use a thin layer of dope on the beveled surfaces, and crank down really tightly?
    I am enclosing two pictures so to help illustrate the situation.
    If the "hose" has the same size adapters, just put some pipe compound on the beveled faces and screw the new connector onto them. Do not "scour" the beveled ends, they are fine just the way they are.
    Home Builder ckl111's Avatar
    Apr 2009
    Ontario
    Follow the instructions that came with the kit. You only use GAS APPROVED pipe dope on the male threads screwing the adapters into the shut off and the regulator. Don't use regular plumbing dope; the gas can react with it.
    DO NOT use any pipe dope at all on the flared (beveled) end of the adapter and couplings. Not on the threads nor the bevelled surface. The flare on the adapter and the corresponding coupling on the gas connector is what forms the gas seal. Pipe dope contaminates this seal and can act like a lubricant on the threads that can loosen the connection over time. "Everything was pretty freakin' tight" and it is supposed to be. The last thing you want is a loose gas connection.
    You can usually reuse the old adapters but from the pictures, it looks like your adapters have been contaminated by pipe dope on the flared ends. I would replace them if it were me. Just make sure to use a properly sized wrench on either side of the connection when loosening and tightening and you shouldn't damage the shut off or regulator.
    Make sure to use liquid leak detector on all the connections after you are finished to check for leaks. Gas is one thing I take a lot of precautions with. A leaky faucet may cause water damage but a leaky gas fitting can blow your house up.
    http://0323c7c.netsolhost.com/docs/F...0appliance.pdf
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    I'm with HJ.
    cki111's final recommendation is the only valid one as far as I am concerned and this is after 60+ years in the business without EVER blowing anything up. I don't know where you would find a "gas approved" pipe joint compound which as not also a "common" one used on EVERY type of connection.
    Apr 2009
    Ontario
    I don't know about the rest of North America but around here you can get a cheaper pipe dope that is not approved for gas fittings. http://www.gfthompson.com/index.php/...no-leak-detail
    You are right that the "gas approved" pipe dope can be used for EVERY thing else but the cheaper stuff cannot be used for Gas. At the local Home Depot, the gas approved stuff is double the price. http://www.gfthompson.com/index.php/...ealants-detail
    To add to the misinformation, some stores or their websites say a particular pipe dope is suitable for natural gas but a check of the manufacturers web site shows it is not recommended for gas.
    I don't know what you normally use but I just wanted people to be aware there can be a difference. Just read the label.
    If you want to use T-tape, there is "Gas Approved" T-Tape too. Around here, it's yellow for easy identification.
    quote; If you want to use T-tape,
    In the first place there is NO approved "T-tape". Second, there is no way any competent person would use TPFE tape on a flared joint. In addition, once a flare joint is compressed. the gas CANNOT react with it, if it even it could do that normally.
  1. 3/4 inch supply line to master bath, but 1/2 inch line at shower valve?
    By barbourdg in forum Shower & bathtub Forum & Blog
    Last Post: 03-05-2013, 12:52 PM
  2. Toilet runs, after supply line replacement
    By loke in forum Toilet Forum discussions
    Last Post: 06-07-2008, 08:07 PM
  3. Question about moving stove line to dryer.
    By enviroko in forum Electrical Forum discussion & Blog
    Last Post: 08-26-2007, 12:29 PM
  4. Cost to have gas line ran to stove?
    By enviroko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2007, 07:27 PM
  5. Supply line
    By Cookie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2007, 02:23 PM
