Results 1 to 5 of 5
Thread: Cutting through a 2" brass valve?
    Default Cutting through a 2" brass valve?
    My pool is plumbed in 2" copper. After 40 years, all but one of the brass gate valves has stripped it's stem, and of course, the manufacturer has gone out of business and I can't find a match to swap parts with.
    I've got four valves side by side, feeding into a manifold, and I'd like to leave the manifold intact. There's a union at the other end of the manifold, so my thought is to pull the innards from all the valves and cut the valve bodies in half with a sawzall (the valves are spaced too close together to get to the middle valves with a grinder). Then I can sweat off the valves one at a time, rather than trying to torch four 2" valves all at once. (and yes, I've got mapps and acetylene torches)
    Has anyone sawzall'd a brass valve? Is the alloy soft enough to cut with a bimetal blade? I might be able to get to the outside valves with a grinder, but I definitely don't have clearance to reach the middle pair.
    Or am I missing something and there's a better way to skin this cat?
    Mar 2011
    Long Island, NY
    Quote Originally Posted by jeffeverde View Post
    Jeff, first of all, I am not a plumber, but I do have a sawzall. I have used the saw to cut through 2 inch galvanized pipe, and I would imagine that a brass valve should cut like butter with a regular fine tooth metal cutting blade. I would like to hear what the pros say on this too.
    Cut the valves through the ends just past the end of the pipe going into it. Almost any metal cutting blade will cut the brass. As a side issue, using copper for a swimming pool, I assume it is a swimming pool, usually results in "green" stains around the openings and deterioration/erosion of the copper tubing.
    41 years and not a stain (my parent's house). Now if only my dad had done periodic maintenance on the valves
    Thanks for the advice. I was pondering changing the above-ground plumbing to PVC. But then I figured - "the first set of valves lasted almost 40 years - why mess with a good thing".
    There is probably NO periodic maintenance which would have "saved" the valves. The problem is the composition of the brass and the chemicals in the water. "Better" valves might have been a better option, but pool builders are not known for using "quality" materials when a cheaper one works just as good.
  1. "real-world" vintage cast iron pipe cutting?
    By zimmee66 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2013, 01:07 PM
  2. Electrically Actuated Full Port Brass Ball Valve 3/4"
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2012, 09:48 AM
  3. 3/4" by 3/4" brass check valve?
    By kenhreed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2009, 07:55 PM
  4. Cutting a brass nipple
    By MikeG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2005, 06:59 AM
  5. "Tuscany Brass" bath / shower faucet parts?
    By BrianM in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2004, 05:48 AM
