Results 1 to 5 of 5
Thread: How to assemble close nipples properly without a hex center?
    DIY Junior Member cwilliams2000's Avatar
    Mar 2013
    Boston
    Default How to assemble close nipples properly without a hex center?
    I am planning to replace a failed well pressure tank and part of the install will involve a few 1" close nipples. I have to be honest I have always dreaded these and always been able to find a hex version which seem terrific to me, but this is obviously due to the fact I don't know how to put them together. I can't grab them with tools so can you tell me the way to put these together and get enough threads in? Thank you very much!
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    Just tighten what the close nipple goes into. For example, if you are putting a close nipple between two elbows put a wrench on one elbow to hold back and tighten the other. I say elbows in my example, but the two fittings could be anything.
    Elementary, dear Watson. You DON'T tighten the close nipple. You tighten whatever you are screwing on to the close nipple. Doing that will tighten the nipple at the same time.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Now I feel much better. I figured that one out by myself some time ago.
    Of course, I'm still embarrassed about it taking me so many years to figure out something even simpler: When I moved to Texas in my 30s, the weather forecast said "t-storms". Suddenly, a light bulb turned on: "T-storm" --> "Thunderstorm", "T-bird" --> "Thunderbird" -- oh, gee, they're the same car...
    Does that mean that "T-Mobile" is an automobile also?
  1. Proper way to assemble brass fittings
    By BimmerRacer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2009, 11:33 PM
  2. Trouble with Nipples
    By advertguy2 in forum Shower & bathtub Forum & Blog
    Last Post: 09-03-2009, 05:46 AM
  3. Need help with leaking nipples
    By mears in forum Irrigation / Sprinkler Forum
    Last Post: 10-07-2008, 11:13 AM
  4. Nipples
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-19-2008, 03:48 PM
  5. Brass Nipples
    By raeiken in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2006, 06:59 PM
