Results 1 to 7 of 7
Thread: No floor drain for softener
    Default No floor drain for softener
    Hey guys I just got a Marlo water softener. I have no floor drain for it and send the discharge overhead. What should I do for the brine tank overflow line? Stick it in a 5 gallon bucket?
    Most people don't do anything with it. Wise people check the salt (and water) level like weekly to catch a problem before they have salt water on the floor.
    A 5 gallon bucket may over flow also. It depends on how long water flows into it.
    Jan 2012
    California
    Most systems use a timed refill and include a safety float in the brine tank for proper redundancy to prevent water from overfilling the brine tank due to a power failure during refill, or a leaking and worn brine valve.
    The gravity overflow is rarely connected unless the system is installed in a highly water sensitive area.
    Softeners should not typically be installed in highly water sensitive areas without proper floor drainage in case of a leak.
    Central Florida
    Another leak a 5-gallon bucket or a safety float won't address:
    http://www.terrylove.com/forums/show...l=1#pos***5737
    If this were in a super-critical area, I'd probably put the brine tank inside a cut-off 55-gallon drum, with a water sensor in it tied to the home security system.
    Can anyone confirm that a Marlo Water Softener has a Fleck head? I was told it does.. Or at least that Fleck makes the heads they use?
    Bumping this to find out if Marlo heads are made by fleck...
    You can go to www.fleckcontrols.com and look at some pictures and see if yours matches any of their valves.
    But if you find one, it may look like as if you have a Fleck whatever but... yours may have a part or two that is proprietary to only Marlo.
  1. Can I drain my water softener in a floor drain?
    By amateurplumber1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-15-2013, 09:18 AM
  2. How to prep a laundry room floor with floor drain for tiling?
    By benze in forum Remodel Forum & Blog
    Last Post: 08-30-2010, 12:18 PM
  3. relocating drain in a slab floor - concerned about floor
    By yvrtogo in forum Remodel Forum & Blog
    Last Post: 06-11-2010, 11:06 AM
  4. Connect second floor shower drain into first floor kitchen drain
    By lanthoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2008, 07:02 AM
  5. 2nd Floor Washer/Waterheater - Overfloor Floor drain tie in.
    By zhomes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2007, 12:30 PM
