Results 1 to 7 of 7
Thread: Gap between shower pan and studs
    DIY Junior Member Bratan's Avatar
    Feb 2013
    New York
    Question Gap between shower pan and studs
    Looking for an advise
    I'm installing 4 piece pre-made shower (pan, back wall, side walls) and there's a big gap of 1-1/2" between back wall studs and shower pan
    What would be the best way to breach the gap, extend studs? 2-3 layer of 1/2" backerboard or some kind of long wood planks (parallel to the floor)? Some other option?
    Single wood plank will take care of pan problem, but then there's back wall that needs to be installed and then on top of it there will be drywall (going to the ceiling)....
    Construct a plumb stud pocket
    according to the Roughing-in
    information on the back page.
    I would fir out the walls to make them plumb and straight.
    Feb 2013
    New York
    Thanks Terry! I never heard about firring out, is it something like in this video? http://youtu.be/MLPEUZ7MAUE
    You can either sister wood studs alongside, or pick up a small table saw and shim the wall out. A table saw is nice for getting just the right size shims.
    http://www.dewalt.com/tools/machiner...s-dw745_2.aspx
    Feb 2013
    New York
    Wink
    That sounds like a plan, will make 1-1/2 shims out of new stud planks (probably just cut them in half). Thank you Terry!
    BTW it's funny, but that's the exact table saw i have
    If the walls are not perfectly flat and plumb and in plane with each other, just take a new, full-sized stud and screw/glue it to the side of the existing ones and make it nice and plumb and square. Quicker and easier than ripping a bunch of studs that won't take into consideration any bowing or other issues unless you want to try to make some really long tapered shims, or if bowed, curved, which would be really difficult.
    Feb 2013
    New York
    Good point! Actually I just got another suggestion from someone. I don't have to rip/cut anything, just buy 2x4 and screw them to the existing stud but at 90 degree angle, so it will be like "T" shape if looking from top/ceiling. Since 2x4 is actually 1.5 inch it would make the gap. But yeah if wall is uneven or new studs wrapped I'll have a problem...
  1. "Notching" studs vs. holes in studs for copper pipe?
    By ironspider in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2013, 08:02 AM
  2. tub/shower surround walls - attach directly to studs or install wallboards first?
    By johnny-canuck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2012, 06:33 AM
  3. Pex and 2x6 studs
    By biking_viking in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-18-2008, 11:52 AM
  4. installing 3 piece shower wall on open studs
    By rjdrad1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2008, 04:00 AM
  5. How Do I Run PEX Through Corner Studs?
    By MuddlingThru in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2005, 05:40 AM
