Results 1 to 6 of 6
Thread: Toilet for 12 3/4" drain placement.
    DIY Junior Member Barbaraa's Avatar
    Mar 2013
    Vancouver, BC
    Default Toilet for 12 3/4" drain placement.
    In my recent bathroom reno, the toilet drain was moved and placed at 12 3/4" rather than the standard 12". The toilet I purchased was a Cadet 3 which sits further from the wall according to other threads. So, combined, the toilet sits too far from the wall.... Can you recommend a toilet that might fit better?
    At 12-3/4" most bowls will be out from the wall. Which I perfer over having the tank touch the wall.
    Some toilets have less space behind the tank then others.
    Most standard 12" toilets will have between 1/2" and 1-1/8" behind the tank at 12"
    Something like a TOTO Drake II would have 1/2" behind the tank at 12", but then that's an elongated bowl.
    Is it the space behind, or how far it comes out into the room?
    Mar 2013
    Vancouver, BC
    The space behind the tank is over 2". Not how far it comes out into the room.
    Most toilets have space behind...yours sounds like it would have had a pretty large space even if the flange was at the design distance of 12" (i.e., that gap would be 3/4" smaller, and still over an inch). There isn't much of anything you can do with the existing toilet, but a close review of the spec sheets of other toilets should find you one that will have a smaller gap. Most people live with it unless they need the room in front of the toilet. Many of the Toto toilets are designed with a 3/4" gap, so would still be 1.5" (3/4 + the 'error' in your flange of 3/4").
    Mar 2013
    Vancouver, BC
    Thank you Terry and Jim.
    Rough in size is often misunderstood. We are accustomed to quoted size numbers to be a finite number, but this is not true with toilet rough-in. It is often impossible for a plumber to center a toilet flange at exactly 12" from the finished wall as the frequently is a floor joist that prevents it. So, the flange may be plus or minus a little. Fortunately, toilet manufacturers allow for this when they cast the their toilets. A 12" toilet does not require the full 12". There is always space between the tank and wall. In your situation, this means a somewhat large space, but sometimes the flange may be less than 12" and in that case, the 12" toilet may still fit, it will just be closer to the wall. Sometimes the offending floor joist is is such a bad position that the flange can not be even close to 12", and that presents other problems that have to be dealt with.
  1. Connect toilet directly over main drain. 3" clearance under subfloor to top of drain.
    By zx6e in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2012, 09:05 AM
  2. Slope requirement on 3" horizontal drain - 1/8" or 1/4" per foot? Drain design?
    By Kubota_Kid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2012, 11:47 AM
  3. toilet drain 3" or 4"?
    By zxed in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-02-2009, 08:08 AM
  4. Toilet w/3" flush valve into 3" drain pipe
    By Jerry Ryan in forum Toilet Forum discussions
    Last Post: 08-21-2007, 06:51 AM
  5. Shower drain placement
    By Bryan123 in forum Shower & bathtub Forum & Blog
    Last Post: 03-19-2007, 07:28 PM
