LeBlanc
- Messages
- 35
- Reaction score
- 0
- Points
- 6
We have a water-odor issue, but it's only on the Hot Water side of our well-water system (with a water softener).
My family owns a house in Michigan we use sporadically. The well water system is connected to a water softener that’s been in place for about 12 years.
When we leave the house, we flip the switch to the well to “off,†open all faucets, turn the gas HWH off, and during the winter leave the heat on its lowest setting. We do not empty the hot water heater.
Upon our return after a few weeks or more, we start everything up and though the cold water is fine, the water from the HWH has an odor, sort of like rotten eggs. Before re-lighting the HWH, I’ve tried to “flush†the water inside the HWH by opening the hot water side of all faucets to run for an hour. This allows the system to dilute the water that has been standing in the HWH so that the odor subsides. If we use the house for a few days (showers, dishwasher use, etc) eventually the hot water does not include an odor.
Any suggestions as to how I can avoid this issue, to keep from having stinky water, and also to keep from having to run faucets for an hour? If a certain type of salt (or salt substitute) will work, I’ll try it. Thank you.
