Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Switch with GFI
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default Switch with GFI
    This is probably one for Leviton. I have never seen this, have you?
    I'd like to have in one strap a GFI with a rocker switch, but no outlet.
    I'd like to see the switch be the same size as one of the switches in a tandem decoura switch. The GFI buttons could be below it.
    I'll be installing a fan/light in a shower stall and am looking for the easiest and cleanest look. The switch box will have a second strap with three switches on it, for another fan/light/heat rig. The light switch on that one will also control the vanity light.
    There is no useful purpose in a receptacle at the door, and the narrow switch which is typical will stand out.
    Anyone have a lead?
    Again, I expect that it just does not yet exist.
    There are wire in GFCI devices without any component (i.e., switch or receptacles) and of course, you could always install a GFCI CB in the panel, but then, if it trips, it isn't as convenient (but in a well designed system, it may never trip).
    Jan 2012
    Los Angeles, CA USA
    Yes, a blank face gfi exists, but I don't want to put in three straps if I could help it. And I'd as soon not put in a gfi breaker, even though it would be right across the hall in a sub panel. The house dates back to the late '40's and I am dubious of what the wires would do being down stream of a GFI breaker. I imagine all sorts of trouble with that.
    If the panel has room (and you can find a GFCI breaker that fits!), being right across the hall may mean a new run wouldn't be too bad.
    Jan 2008
    The Leviton Decora listings show a single rocker switch over a single receptacle with GFCI buttons in the middle. Don't see anything without a receptacle.
    Jan 2012
    Los Angeles, CA USA
    Yes. I understand.
    Jan 2012
    Los Angeles, CA USA
    The inspector will insist on Arc Fault with any new circuits.
    Jun 2007
    North Carolina
    Quote Originally Posted by Homeownerinburb View Post
    not for a bath
    Jan 2012
    Los Angeles, CA USA
    not for a bath
    It never hurts to ask.....but yes, I think you are correct on that one.
    What would the GFCI monitorl if there were no outlet?
    Mar 2011
    Houston, TX
    You should contact them and have them make a special one for you.
    Jan 2012
    Los Angeles, CA USA
    Right after I start to lay golden eggs.
    Jan 2012
    Los Angeles, CA USA
    The fan/light combo in the shower stall, which the manufacturer and my inspector want to have on a gfi.
    My inspector is ok with me using the vanity gfi for this, now I just need to get up in the attic and see how the conduit runs.
    If you are lucky, the feed could go to the GFCI receptacle first and then to the switch. If so, all you would have to do is change the wire from the line side to the load side.
    As with any GFCI, anything wired on it's load side...anything you deem desirable or required.
  1. Can I use a (mistakenly purchased) 3-way switch as a single pole switch?
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 05-22-2012, 08:00 AM
  2. Cconvert 2 gang switch to 3 gang switch
    By soft in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2012, 03:17 AM
  3. 3-way switch feeds another switch?
    By yar02169 in forum Electrical Forum discussion & Blog
    Last Post: 08-23-2011, 01:24 PM
  4. Adding a Single Pole switch coming drawing power from 3 way switch
    By eduvall in forum Electrical Forum discussion & Blog
    Last Post: 10-22-2009, 07:10 AM
  5. Lighted switch on switch loop?
    By JAR8832 in forum Electrical Forum discussion & Blog
    Last Post: 06-16-2008, 04:16 PM
