Results 1 to 5 of 5
Thread: Price Pfister diverter valve
    DIY Junior Member macguy59's Avatar
    Mar 2013
    Illinois
    Default Price Pfister diverter valve
    Had a problem since day one of moving into the condo. I have a 3 handle setup in our shower. The center handle is the diverter that when turned redirects the water flow to the shower head. It does but water is also still pouring out of the faucet. It's overwhelming the drain to the point that the tub gradually fills with water while showering (making for a grimy looking tub). I pulled the valve and had it identified as a Price Pfister (PF stamped on the valve assembly). I opted to replace the entire assembly rather than just the washers. The new valve looks identical to the one I'm replacing. It screwed in fine and the handle went on like it should but no joy. Still have the same problem even with the new valve. What else do I need to look at/for ?
    Plumber jimbo's Avatar
    Assuming you put the new stem in correctly ( we can talk about that later) then we can mention 2 possibilities:\
    1) Water pressure in the house way too high. Easily checked at a washing machine hose connection, with a simple guage available at hardware store.
    2) The tub filling up could indicate an not-related drain clog. But if the pressure is too high, it might be overwhelming the drain.
    Check your pressure, if OK....take out the diverter stem, inspect, and post photos.
    Mar 2013
    Illinois
    Thank you for the quick reply. I suspected a drain problem first so I had Roto Rooter over here to snake it. They couldn't find a clog. I didn't replace just the stem. I replaced the entire valve assembly so I'm not sure what I could have done incorrectly but I will pull it back out and take a picture. If it's a case of water pressure being too high . . . I should be able to reduce it at the main shut off correct ?
    Mar 2013
    Illinois
    Well in the process of taking the new valve assembly out to take a picture of it, I immediately saw what the problem was. One too many of the large flat white washers which was preventing the valve stem from seating all the way. I couldn't spell plumber yesterday but today . . . lol
    Because the diverter is a "double seated" valve the distance it goes in is critical. Therefore,either an extra washer, or a missing one, will cause the symptoms you had.
  1. Price Pfister diverter valve leaking by
    By mbrinkma in forum Shower & bathtub Forum & Blog
    Last Post: 09-09-2012, 01:02 PM
  2. Price Pfister Diverter problem
    By FrancisKuo in forum Shower & bathtub Forum & Blog
    Last Post: 12-27-2011, 10:39 AM
  3. Price Pfister shower diverter
    By wstaubin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2011, 09:30 AM
  4. Price Pfister Kitchen Diverter Tee
    By pmizell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2009, 05:20 PM
  5. Price Pfister Shower Diverter Removel
    By Adam S in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2004, 04:48 AM
