Results 1 to 9 of 9
Thread: Water pump
    DIY Junior Member Randy54's Avatar
    Mar 2013
    Coatesville,Pa
    Default Water pump
    My pump comes on a lot with no water running. There are no leaks in the house. I'm told the most common problem is that the bladder loses air. I have a Gould model V60 . How can I find out the proper amount of air to put in. Thanks
    Feb 2011
    NW Ontario, Canada
    There is a sticky that explains it in detail.
    http://www.terrylove.com/forums/show...nk-Maintenance
    That said, you must still be losing some water somewhere for the pump to come on.
    Jan 2008
    If the pump cycles when no water is being run, it is a sure sign of a leak. The leak can be anywhere between the pump and the fixtures in the house.
    Moderator valveman's Avatar
    Mar 2006
    If you are sure no water is running then it is probably the check valve leaking back.
    Mar 2013
    Coatesville,Pa
    Thanks for the replies. Is the check valve on the line. Or on the pump itself?
    Mar 2006
    Could be either or both. What kind of pump do you have, above ground jet pump or submersible?
    Mar 2013
    Coatesville,Pa
    Not sure of the make. Although I think it's a golds. It's sub
    Jan 2008
    The pump has a check valve, and it is pretty common for he installer to place another in the drop pipe.
    It is also very possible that the drop pipe or lateral line is leaking, particularly if it is galvanized pipe.
    Mar 2013
    Coatesville,Pa
    It looks like the pitless adaptor is bad. Thanks for all the help. This site is very informative!
  1. locating back up sump pump in brackish water, minimizing rusting of pump
    By philip o'dowd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2011, 11:05 PM
  2. How do I know if my water powerd sump pump is running and not the primary pump?
    By milkmoney11 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-12-2010, 07:30 AM
  3. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-20-2009, 09:33 AM
  4. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2007, 04:49 PM
  5. New Well Pump, but Pump is still coming on when no one is using the water
    By glorygirl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-27-2005, 05:43 PM
