Results 1 to 2 of 2
Thread: OK...another Noobie question...how much water should cause the well pump to cycle
    DIY Junior Member Jay Jay Ramirez's Avatar
    Mar 2013
    Default OK...another Noobie question...how much water should cause the well pump to cycle
    CHecked pump tank pressure and it was a bit low (30-50 cutoffs...read about 18-19 psi refilled air to ~26-27 psi). Was wondering how much water should come out of a 20 gallon well pump tank to have pump cycle? Tank seems to hold pressure. Pressure at night is the pressure in the morning when not running water. No short cycling.Toilet flushing doesn't cause pump cycling when at max pressure. Likely obsessing about this. I assume I'm looking for short cycling or drastic drops in pressure if well tank or accessories have gone bad. Thanks in advance.
    JJ
    Feb 2011
    NW Ontario, Canada
  1. Pump cycle question
    By boomer2 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-08-2011, 08:05 AM
  2. Water Hammer At Pump Cycle Stop
    By terrysii in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-07-2008, 09:05 AM
  3. Stupid noobie question about shower remodel
    By boston confused in forum Shower & bathtub Forum & Blog
    Last Post: 05-12-2008, 04:27 PM
  4. Noobie with question on system design...
    By cc_rider in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2007, 04:48 PM
  5. NEC Cycle question for GFCI..
    By ygdron in forum Electrical Forum discussion & Blog
    Last Post: 11-15-2007, 12:07 PM
