Thread: Joist under tub drain.
    Home Builder ckl111's Avatar
    Apr 2009
    Ontario
    Default Joist under tub drain.
    Replacing an old tub with a new fiberglass one. The tub drain is directly over the floor joist. Is it ok to offset the drain and overflow with some 45s? The water drains fine but I wanted to check if there was a better way to do this. With the offset, we only had to slightly notch the joist at an angle. I can sister a new 2x8 on the other side later.
    That would be fine.
    Normally I offset a little differently, keeing the santee vertical and 45 over the overflow tube, but what you have works too.
    Apr 2009
    Ontario
    Keeping the tee vertical was the original plan but the copper was in the way. I didn't want to move it unless it was necessary. The old drain came down the other side of the joist but that side is boxed in with a kitchen bulkhead that wont be accessible until the kitchen demo is complete.
    I see what you mean now though. If I used a regular 45 instead of the street 45, maybe I could have offset it a little more to clear the pipe and then 45 the overflow keeping the santee vertical.
    Thanks Terry
  1. Tub Drain and Floor Joist
    By diydude in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2013, 10:26 AM
  2. tub drain thru joist layout
    By kevinrx1 in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2013, 06:24 PM
  3. Tub Drain/Joist In The Way
    By akmacs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2009, 07:55 AM
  4. Moving tub drain (through joist)
    By hans_idle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2007, 02:41 PM
  5. Joist meets Drain - now what?
    By lhartl in forum Shower & bathtub Forum & Blog
    Last Post: 02-12-2007, 06:14 AM
