Results 1 to 2 of 2
Thread: is this a right way to terminate a drain line?
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default is this a right way to terminate a drain line?
    Please refer to the photo. It is in the basement. The branch line is first floor's bathroom drain pipe which has its own vent. Should I vent that vertical main line or just cap it like the photo shows?
    The photo is too washed out to see what you are referring to, but putting a plug in the end of a fitting IS the right way to terminate A generic drain line. BUT it may not be the way to terminate YOUR drain line, depending on other factors your photo and description may not tell us, such as WHY that fitting is there.
  1. Ventless Pump: 1) Any good? 2) How to terminate?
    By bucky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2011, 07:04 AM
  2. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  3. Adding an additional drain waste line to an existing line.
    By hdmstng in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2011, 04:49 PM
  4. Connect drip pan drain line into T&P drain line?
    By Briarius in forum Water Heater Forum, Tanks
    Last Post: 02-26-2009, 02:35 PM
  5. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
