Results 1 to 4 of 4
Thread: Stuck drain valve.
Hybrid View
    DIY Junior Member MichaelJ's Avatar
    Mar 2013
    New Jersey
    Default Stuck drain valve.
    A drain valve on my hydronic heating boiler is completely stuck. The valve does not have a bonnet, the stem seats in a valve body. A gland nut covered some kind of a packing which was like rubber and crumbled easy. The handle end of the stem is broken off. The valve leaks slowly, only a bit faster than evaporation. When I discovered the leak the valve was encrusted with calcium deposit end rust already eaten through the metal wall. I tried to use big wise grip and 12” pipe wrench on the stem without any success. I suspect that even when I unscrew the stem it will be unusable. One reason is broken off handle. To replace the whole valve I’m afraid to do something to thread in cast iron body of the boiler. The valve is installed using some kind of plumber putty that is now hard as a rock. Any advice how to approach this problem? Another question would be how to drain water from the boiler when the drain valve is unoperative?
    Michael J
    Aug 2009
    South*East
    That looks like a water heater not a boiler. If it is a water heater it's time to replace it.
    John
    Mar 2013
    New Jersey
    It is Peerless boiler made probably in 1960 (serial number starts with 60-...), 160k BTU, still going strong, cast iron body.
    IT is a brass valve into a cast iron boiler. You will NOT do anything to the boiler when you remove the valve using a BIGGER wrench. Turn off the water to the boiler, close the valve to the expansion tank, open the relief/safety valve to remove the pressure, then close it so no air gets into the system. Remove the drain valve and QUICKLY screw the new one in with minimal water leakage.
  1. Shut off valve stuck
    By blitziger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2010, 08:54 AM
  2. Stuck Water Heater Drain Valve
    By goat1of2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2008, 01:59 PM
  3. stuck shutoff valve
    By zeroweek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2008, 05:19 PM
  4. stuck foot valve
    By wildernessj in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-27-2008, 11:08 AM
  5. Stuck diverter valve
    By spresco in forum Shower & bathtub Forum & Blog
    Last Post: 01-28-2007, 07:26 PM
