Results 1 to 10 of 10
Thread: Standard procedure for mounting pedestal sink?
    DIY Member coldsolderjoint's Avatar
    Aug 2012
    Keansburg, NJ
    Default Standard procedure for mounting pedestal sink?
    My mother wants to re-home our old pedestal sink to her place.
    Its in my yard with the two pieces separate currently.
    When I removed it from our house, there were two toggle bolts holding the basin part against the wall, and the pedestal part was holding it "up". If i had removed the pedestal part by itself, I'm pretty sure the basin part would have ripped right out of the wall.
    Is that how its supposed to be? How should I re-install it in her place?
    (It will be replacing that '60's Kolher sink you guys helped me with previously)
    Pedestal sinks almost never hang on the wall. They NEED the pedestal, unless it is a sink where the pedestal can be an afterthought, which I doubt yours is. You install the pedestal, then set the sink on it and fasten it to the wall.
    Aug 2012
    Keansburg, NJ
    Thanks! I guess the last guy to work in this house didn't fasten the pedestal, it was just sorta jammed under the basin part.
    Many, if not most, are installed that way. The sink holds them in place once the sink is secured to the wall.
    Home Builder ckl111's Avatar
    Apr 2009
    Ontario
    After everything has been aligned and tightened up top, I usually put a little bit of silicone between the floor and the back of the pedestal to hold it in place.
    Aug 2012
    Keansburg, NJ
    Thanks guys! This forum is petty great in that we DIY can get this info.
    My mother called off the project, but now I know for next time I have to put in a pedestal sink :-D
    quote; but now I know for next time I have to put in a pedestal sink
    By then you will probably have forgotten it, and have to ask again.
    Mar 2011
    Long Island, NY
    Why HJ, because it's so complicated?
    Nov 2009
    Victor, MT
    Next time the lesson will probably involve the height of the trap arm, regardless.
    Aug 2012
    Keansburg, NJ
    oh well.. maybe someone else who is smart enough to search will learn from this thread
  1. Pedestal sinks. Standard mount dimensions?
    By DougDoingRemodel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 11:32 AM
  2. Need opinion on mounting bathroom sink
    By Dan W. in forum Remodel Forum & Blog
    Last Post: 08-29-2010, 08:09 AM
  3. Pedestal Sink Mounting Bracket
    By RL1964 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2008, 07:25 PM
  4. Cost to install pedestal sink vs. cabinet sink in new construction
    By lousygolfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2007, 12:04 PM
  5. Sink mounting bracket ??????
    By Bigbobdallas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2006, 05:39 AM
