Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: system Recommendations for well
  1. #31
    DIY Junior Member patrick2269's Avatar
    Jan 2013
    NC
    A pump only has to move water for the static water level but since it is at 200', I'd guess it was a 3/4hp but we don't know the gpm.
    Have you talked to the camera guy about iron causing corrosion?
    he said some corrosion on the casing witch is letting iron build up on the casing walls but no holes in the casing
  2. #32
    If your water contains iron, the soluable iron is oxidized as the water pressure decreases and comes in contact with air and that causes rust to build up on the casing in the draw down area at the top of the water column.
    Lining the well will not stop that or stop the effect of your acid water. If it were me, I'd have the well cleaned (depending on the cost) and get a backwashed mixed bed AN filter and a water softener.
  1. Recommendations for system
    By woodguy00 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-20-2012, 05:47 PM
  2. Recommendations needed to improve my water filtration system.
    By dergrah in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-20-2011, 11:40 AM
  3. Looking for treatment system recommendations
    By Fishguy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2011, 09:31 AM
  4. sump system recommendations
    By fozzy12 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2010, 10:07 PM
  5. 1.28 GPF recommendations
    By buckler in forum Toilet Forum discussions
    Last Post: 01-08-2009, 03:45 PM
