Results 1 to 3 of 3
Thread: need help with Whirlpool tub
    DIY Junior Member dafichter's Avatar
    Mar 2013
    Missouri
    Default need help with Whirlpool tub
    I bought Oasis Whirlpool tub several years ago. Due to health reasons I did not intall it. Now I am remodeling my bathroom and I want to intall it. I do not have the directions anymore. I contacted Oasis and they send me directions but they for a different model tub (mine is discontinued). The directions are for a tub that has no platform attached to the base. There is a platform attached to the base of my tub. The platform is as big as the ledge (lip) of the tub.
    Do I need to put blocks under the base? If not, how do I shim it?Name:  100_0849.jpg
    Also, do I instal the drain first or do I frame the tub and then intall the drain? Any suggestions abut framing it? It will be set against two walls and I will build a wall in the frongt and on the side. I have experience with home improvement and plumbing, but this is the first whirlpool tub that I install.
    Just to clarify-the first photo is from underneath the platform. Thanks again.
    I would at least put a ledger board at the back, and have a framed wall at the front.
    You can set the ledger and the front wall to level, a little higher to lift the tub above the floor, and then set several piles of mortar down, set the tub down on those and let the mortar squish out. When dry, those will support the base of the tub. You can't hang the tub from the top unless it's also supported from the bottom of the tub.
    If you plan to shower there and tile around the tub, you will need some flanges at the wall to divert water back into the tub. Those can be installed with Silicone.
    Mar 2013
    Missouri
    Thanks for the help! That makes a lot of sence. i appreciate it.
  1. how to support whirlpool tub...
    By majong in forum Shower & bathtub Forum & Blog
    Last Post: 06-16-2009, 07:55 PM
  2. Cement under whirlpool tub
    By countryhouse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2009, 08:43 AM
  3. whirlpool
    By hottub in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2008, 10:44 AM
  4. Whirlpool heater?
    By mattt19 in forum Shower & bathtub Forum & Blog
    Last Post: 03-08-2008, 06:37 AM
  5. Whirlpool FilterSense
    By patrick2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2007, 11:04 AM
