Results 1 to 11 of 11
Thread: How to remove bowl with rusted bolts?
    DIY Junior Member Bratan's Avatar
    Feb 2013
    New York
    Question How to remove bowl with rusted bolts?
    I'm trying to remove old toilet bowl (lower part) from the floor but two bolts/nuts are rusted and turn freely (both bolt and nut)
    How do I remove it? It doesn't go high enough for me to use hacksaw or dremel. I'm thinking of just breaking ceramic parts of the toilet near those bolts, but afraid whole bowl might crack. I will throw it out anyway...
    Here's picture of the nut.Name:  toilet_nut.jpg
    Would love any advise!
    Aug 2009
    South*East
    If you break it there will be no way to reset it. Haven't seen one yet that I couldn't get a hacksaw blade under.
    John
    Apr 2012
    New York, NY
    I would think that you could clean that schmutz away from the nut and hacksaw or dremel through both. Also, why not Dremel the nut vertically, in two locations then just peel it back off the screw? I have done that more than once.
    If you are going to dispose of the toilet bowl anyway, just hit the china with a hammer right next to the bolt. It most likely will not crack the bowl above, just the area around the bolt. However, it wouldn't hurt to plunge out the preponderance of what's in the bowl beforehand, just in case.
    You can saw the nut on the top side and then split it off. Most people assume it has to be cut horizontal to the floor. You can also cut down on the nut from the top.
    Or if you don't mind scratching the porceling, a sawzall and lean into it.
    Or if the bowl is toast anyway, you can tap out the porcelain around the bolt with a hammer. (eye protection) You will have sharp glass edges that can slice, so be careful with any broken porcelain.
    Feb 2013
    New York
    Thank you Terry and all! I used hacksaw at 45 degree angle and was able to remove both bolts (took me about 40 minutes of sawing hammering and bending)
    Apr 2012
    New York, NY
    Quote Originally Posted by Bratan View Post
    Glad it worked out!
    Yakima WA
    Hope there was a lesson learned here. Next time, use brass or stainless steel flange nuts, washers, and bolts.
    That's why we lock them down at the flange. I buy bolt sets with four washers and nuts.
    The home centers don't sell them that way, but it's how the plumbers buy them.
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    I used an oscillating tool on mine since I was replacing the toilet anyway.
    Bill
    Just a DIY'r
    Feb 2013
    New York
    That's a good idea! I will probably install it like that, flange is a little banged up...
    Yeah for whoever built this house in 1970 I only lived here for 5 years, and every time I do something I find nasty surprises Like double linoleum with tar sandwiched between layers
    Aug 2009
    South*East
    The tar is, tar paper which was common practice when the linoleum was put in.
    John
  1. Fastest, easiest way to cut rusted / corroded toilet bolts from tank
    By augusta in forum Toilet Forum discussions
    Last Post: 04-11-2011, 07:50 AM
  2. Remove bowl to replace seat????
    By dodge in forum Toilet Forum discussions
    Last Post: 05-30-2009, 07:26 PM
  3. Am Standard Cadet Tank/Bowl bolts
    By molo in forum Toilet Forum discussions
    Last Post: 07-24-2007, 07:20 PM
  4. Question about overtightening bowl bolts
    By jumpyg in forum Toilet Forum discussions
    Last Post: 02-09-2005, 08:00 PM
