Thread: pulsaspeeder pump and marlo equipment versus culligan?
    DIY Junior Member famoffive's Avatar
    Mar 2013
    Illinois
    Default pulsafeeder pump and marlo equipment versus culligan?
    We plan to install a chlorine injection system followed by backwashing carbon filter followed by softener. The goal is to take care of coliform, iron bacteria, iron (less than 5 mg) and hardness (32 grains).
    Trying to decide between Culligan and an independent dealer who would use Marlo equipment with Clack heads. They have also suggested we consider a Pulsafeeder pump instead of Stenner to save $200.
    Your thoughts on Culligan versus Marlo? Stenner versus Pulsafeeder?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I would go with the independent dealer. I just don't like Stenner pumps and had to many problems with Pulsafers. With the Stenner you have to change the tube yearly and I had 3 Pulsafeeder motor go out within a year. It took them a month to determine it was under warranty. In the mean time my customers suffered. I think LMI makes the best pump. There only downside is it does not self prime so you have to make sure you don't run out of solution.
    Central Florida
    and in the other corner... I've had a Pulsafeeder pump for over 10 years with no problems, other than during a brief period when I negligently let the chlorine tank run dry. My neighbor has had a Stenner for 3 or 4 years and seems to be happy, although his principal maintenance tool is his checkbook. His dealer is pretty good, though. LMI pumps have impressive specs and are a lot prettier; don't know about costs.
  1. Recirculating loop versus Recirc pump for new construction
    By danrudy in forum Water Heater Forum, Tanks
    Last Post: 01-29-2013, 04:31 AM
  2. Sewage Ejector Pump versus Grinder Pump
    By rlrobinhood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2013, 12:42 AM
  3. Electronic equipment
    By Cookie in forum Electrical Forum discussion & Blog
    Last Post: 09-12-2009, 09:57 AM
  4. 'Above Ground' Equipment
    By MarkMcK in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-22-2008, 05:10 AM
  5. sump pump versus grinder pump or both?
    By rrah in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2007, 08:42 PM
