Results 1 to 7 of 7
Thread: Low hot water flow all faucets
    DIY Junior Member snifferpro's Avatar
    May 2011
    Phoenix, AZ
    Default Low hot water flow all faucets
    A friend just called and said she has low hot water flow to all hot water taps.
    She drained the tank by attaching a hose to the drain valve and shutting off the water coming into
    The hose and opening the pressure relief valve.
    She said there appeared to be no sediment in the draining water.
    She then turned the water back on to the house, filled the tank, and had normal
    Flow at hot water taps.
    Later she called back and said flow was back to a trickle after the water had heated.
    Any suggestions?
    Feb 2011
    NW Ontario, Canada
    Heat traps can bung up causing that.
    May 2011
    Phoenix, AZ
    What is a heat trap
    Feb 2011
    NW Ontario, Canada
    Let me Google that for you.
    http://lmgtfy.com/?q=What+is+a+heat+trap
    May 2011
    Phoenix, AZ
    Thanks, that did the trick
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by snifferpro View Post
    More often than not, it is the reverse. Draining/refilling can cause a large sudden influx of disturbed sediment that can bung up the heat traps.
    It has happened to me more than once and each time after I had turned off the all the water to work on the system. I am tempted to remove the heat traps entirely and probably will the next time I have to fight with it. The problem is my supply lines are hard copper and I'd have to cut and sweat in new fittings.
    May 2011
    Phoenix, AZ
    After getting the old nipples out with considerable effort, I found that the ball in the cold water nipple was solidly attached to the side of the nipple and ball in the hot water nipple
    was floating freely.
    After replacing both, hot water flow is back to normal.
    Again, thanks for the tip. saved a call to the plumber and I learned something new.
  1. Water Pressure Issues - WEAK Flow Then VERY Strong Flow.
    By 3baysofplay in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-09-2012, 04:50 AM
  2. Flow Rate of Kitchen vs. Lavatory Faucets
    By chefwong in forum Plumbing Forum Discussion & Blog
    Last Post: 05-08-2012, 10:15 AM
  3. laminar flow faucets, what happens to the last drips
    By utrwr in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2008, 03:13 PM
  4. delta faucets won't flow, help if possible
    By droptine in forum Plumbing Forum Discussion & Blog
    Last Post: 10-04-2006, 06:49 PM
  5. Flow rate? Flow thru? Water softner restrictions.
    By polocash in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2005, 10:16 PM
