Results 1 to 2 of 2
Thread: tub drain thru joist layout
    DIY Junior Member kevinrx1's Avatar
    Mar 2013
    ohio
    Default tub drain thru joist layout
    Everyone,
    Due to windows I have to drill a 2" drain hole thru the middle of a 2x12 joist to set my tub drain. Before I do, is it okay to run the drain at a 90 degree angle ( long sweep ) on the arm for the p-trap before heading to the vertical vent/waste? It's less than 2 feet each way. See pic...
    Thanks for the advice!
    A 1.5" trap arm can be 42"
    A 2.0" trap arm can be 60"
    You are allowed the 90 bend.
  1. Tub Drain and Floor Joist
    By diydude in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2013, 10:26 AM
  2. Tub Drain/Joist In The Way
    By akmacs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2009, 07:55 AM
  3. Shower layout / joist interference
    By jch in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2008, 09:59 AM
  4. Moving tub drain (through joist)
    By hans_idle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2007, 02:41 PM
  5. Joist meets Drain - now what?
    By lhartl in forum Shower & bathtub Forum & Blog
    Last Post: 02-12-2007, 06:14 AM
