Results 1 to 5 of 5
Thread: Copper to pex without soldering?
    Default Copper to pex without soldering?
    I thought it wasnt possible to go from copper to pex without soldering, except my brother redid our basement so he could live there for a while and he definitely showed me a couple areas where it looks like he installed a connector (and in another area where he did a valve i think) that goes from copper to pex. I have a picture where you can kinda see what im talking about http://i.imgur.com/7u3H4ND.jpg. Whats this all about?
    There are at least two companies that make push-on connectors. These seal with an internal o-ring(s) and use teeth to hold it onto the pipe. One brand is Sharkbite and I think the one you have is made by Watts. This is possible because the OD of each is the same. On the pex side, it also has a sleeve that goes inside to hold it snug, keep it round, so the o-ring can seal and the grippers can hold it in place. At least on the Sharkbite (don't know about the Watts), these are approved and pass codes. On a production basis, it's unlikely they'd be used because of their cost, but are much cheaper than hiring a pro to make that one connection.
    Ah, thanks for the information! It may be a good way to go for a little project i've got since we have a bunch of spare pex laying around. Are these connections reliable?
    They meet all plumbing code requirements. Should last a long time. A soldered connection is a known, long term, reliable connection. These haven't been around all that long for long-term experience. But, they have passed all tests.
    That is either a John Guest fitting or one similar to it. They are fairly reliable, but I have known them to "come off" under the right/wrong conditions. They make one version, not that one however, which have a "locking" ring as a secondary protection against failure.
  1. Soldering copper to brass??
    By David Einhorn in forum Plumbing Forum Discussion & Blog
    Last Post: 01-21-2013, 03:59 PM
  2. Soldering brass to copper help....PLease!
    By b33p3rmcg in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2010, 05:50 AM
  3. Soldering.. copper to copper OR copper to brass.. which one?
    By lithnights in forum Plumbing Forum Discussion & Blog
    Last Post: 03-02-2010, 05:15 AM
  4. Soldering larger copper 1.5+
    By psolutions in forum Plumbing Forum Discussion & Blog
    Last Post: 11-11-2008, 06:40 PM
  5. soldering soft copper
    By scott99 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-07-2007, 03:13 PM
